camry/prius
Old Oct 27, 2006 | 05:13 PM
jcwils@bellsouth.net's Avatar
Default camry/prius
I think Toyota is the clear technology leader for hybrids. How similar is the drive system in the Camry to the well-documented drive in the Prius? Thanks.
Old Oct 27, 2006 | 05:38 PM
jdenenberg's Avatar
Engineering Professor
Default Re: camry/prius
They're almost identical. The main difference is the larger engine in the Camry (2.4L vs 1.5L).
JeffD
Old Oct 27, 2006 | 06:01 PM
CGameProgrammer's Avatar
It's essentially identical; it's HSD. The only real difference is in the numbers (everything's more powerful) and in the fact that the car is much heavier, so the engine ends up running more often when accelerating than with the Prius.
Old Oct 28, 2006 | 12:16 AM
ken1784's Avatar
They're almost identical. The main difference is Prius uses low speed high torque MG2 and Camry hybrid uses high speed low torque.
Prius's MG2 drives the ring gear directly. OTOH, the MG2 of Camry hybrid drives the ring gear through a reduction gear as same as Highlander, RX 400h and GS 450h.
The max speed of the GS 450 is 250km/h, so it has two speed reduction gear to meet the wide speed range.
Ken@Japan
Old Oct 28, 2006 | 09:43 AM
schmidtj's Avatar
Keeping Toyota Solvent
Ken@Japan
Does the Camry have a beltchain in the PSD like the Prius?
Old Oct 28, 2006 | 05:26 PM
ken1784's Avatar
https://www.greenhybrid.com/discuss/...12&postcount=4
It looks Camry does not have chain drive in the transaxle.
Ken@Japan
Old Oct 28, 2006 | 06:41 PM
skywagon's Avatar
My repair book shows it does use a chain.
Old Oct 29, 2006 | 03:34 PM
1. There is no all-wheel drive option for a Camry, right?
2. Is it permissable to ask what street price for a high-end Camry is? (Backlog?)
Old Oct 29, 2006 | 04:34 PM
skywagon's Avatar
1. no all wheel drive
2. 30K, yes hard to get but since factory startup in KY. may be getting better
camrydan
May 8, 2010 06:53 PM
phenderson
Nov 30, 2009 01:05 PM
bugs
May 18, 2008 10:06 PM
Tideland Prius
Sep 29, 2007 10:44 PM
Jason
Hybrid & Related News
13
Feb 12, 2006 09:43 AM
