Camary Dual Problem
Old Jun 30, 2013 | 11:27 AM
rcardwell's Avatar
Default Camary Dual Problem
Our 2007 Camry presented us simultaneous VSC and Hybrid system check lights. I'm curious if they maybe the same problem. The battery is charging according to the dash instrument panel and the 12 volt battery is new and showing 13volts. I don't have a schematic to use so I'm in the dark. Any help would be appreciated.
Old Jun 30, 2013 | 09:14 PM
GeorgiaHybrid's Avatar
Default Re: Camary Dual Problem
Get the codes that are in the ECU and post them here. There are a LOT of things that could be wrong ranging from easy to difficult to fix.
Old Jul 1, 2013 | 08:19 AM
rcardwell's Avatar
I will get the codes today and post them. Thanks for your response.
Old Jul 1, 2013 | 10:32 AM
rcardwell's Avatar
The codes for my Camry are VSC 45 and 51.
Old Jul 1, 2013 | 06:04 PM
I am assuming these are DTC codes (never heard of VSC codes...)
DTC 45 involves a BUNCH of other codes that you will need a bi-directional scanner to get into the system and see what is going on. An example would be C1243 which is an Acceleration Sensor Stuck Malfunction. All of the codes for this DTC involved either Yaw rate or Acceleration rate sensors either being stuck, shorted, open circuit or similar. These all control the ABS braking system inputs.
DTC 51 has two sections, one I don't think is the problem in your case (drivers side airbag squib circuit short). The other area will give you a code C1259/58 or C1310/51 which indicate an HV System Regeneration Malfunction or a Malfunction in the HV System. This code is thrown when you have a problem between the skid control ECU and the Hybrid control ECU.
Both of these codes involve the same control systems and might have had a temporary problem that set the code. Try re-setting the system (clear the code) and see if the code is set again. If it occurs, you will need someone to run some diagnostic tests on the ABS and VSC systems to see what the problem is.
Old Jul 2, 2013 | 08:34 PM
rcardwell's Avatar
Thank you Georgia Hybrid. I will have my dealership run the diagnostics and let you know what I find out. I appreciate your help.
julianwilso
Saturn Vue Green Line
Apr 16, 2008 11:20 AM
wxman3
Jun 2, 2007 10:18 AM
gonavy
Jan 26, 2007 08:42 PM
indylisa_04pri_06feh
Introductions
Jan 11, 2006 11:32 PM
