A/C experience
Old Aug 31, 2006 | 09:16 AM
Orcrone's Avatar
Default Re: A/C experience
Originally Posted by greenGirl
I've been noticing this a lot lately. I think my AC has a mind of its own. Mine kicks off or changes the settings (recirculate, ECO mode, etc) with no reason -- i haven't noticed it happen when hitting bumps in the road. Also, yesterday I noticed that no matter how hard I tried I could not turn the ECO mode on. What gives???
Is it possible you had the temp set to LO or HI? That will disable the system from going into ECO mode.
Old Aug 31, 2006 | 10:48 AM
pbanks's Avatar
Another thing that will turn off the Climate Control Auto mode is if you turn on the front de-mister, which subsequently turns off Recirc & ECO as well.
Old Aug 31, 2006 | 11:19 AM
greenGirl's Avatar
My passanger probably had it on "LO" so its his fault!
I dont think i've ever needed to use the front de-mister, but in upcoming months i probably will so i will keep that in mind.
Thanks for the help! I still don't understand why sometimes the system will kick off or change on its own, though. Maybe I am hitting bumps like others have said...
Old Aug 31, 2006 | 12:21 PM
WVGasGuy
Guest
Posts: n/a
I couldn't get the ECO on when I had the dash/windshiled mode on. I've found in rain or for the outside windows fog up easily and whe I put the fow to the windshield, even when sharing it with the dash vents it wouldn't go into ECO.
Old Aug 31, 2006 | 01:36 PM
schmidtj's Avatar
Keeping Toyota Solvent
It won't. There are at least three modes that preclude ECO. Defroster, Max HI and Max LO. It's documented in the manual. IOW it's "working as designed".
J
sdctcher
Aug 7, 2008 06:36 PM
Mike M
Jan 18, 2006 09:55 PM
'lectronimo
Dec 8, 2005 07:34 PM
gonavy
Dec 5, 2005 02:07 PM
CGameProgrammer
Aug 17, 2005 12:34 PM
