Anyone seen/applied body side molding?
Old Aug 8, 2006 | 05:47 PM
ghull's Avatar
Default Anyone seen/applied body side molding?
Has anyone seen or applied the accessory body side molding to the '07 Camry? I know it's available, but I'd like to check it out before buying. Mine's a Magnetic Grey TCH.
Thanks,
GH
Old Aug 8, 2006 | 07:16 PM
skywagon's Avatar
Talking Re: Anyone seen/applied body side molding?
I have the Mag grey also and would be interested in seeing a pic of the side mouldings. thanks SK
Old Aug 8, 2006 | 07:29 PM
FL07THC's Avatar
Default Re: Anyone seen/applied body side molding?
http://cgi.ebay.com/ebaymotors/2007-...spagenameZWDVW
I saw these today and I think they look good.
Old Aug 8, 2006 | 07:31 PM
TKCamry's Avatar
2007 Toyota Camry Hybrid
Thanks,
GH
One of the posters here has put 5 pics in the share photo section with the body side molding.
https://www.greenhybrid.com/share/br...imageuser=4937
Old Aug 8, 2006 | 07:32 PM
FL07THC's Avatar
These are OEM or so they say. http://cgi.ebay.com/ebaymotors/TOYOT...spagenameZWDVW
Old Aug 8, 2006 | 07:47 PM
skywagon's Avatar
Thanks for the info. SK
Old Aug 9, 2006 | 05:04 AM
ronr's Avatar
"Silver Bullet" Owner
Thumbs up Re: Anyone seen/applied body side molding?
I did not like the look of the unbroken lines of the high doors. They looked too high to me. So, I applied the molding that I purchased from Toyota Parts Store. The color was a perfect match. Looks great on the car. A word of advice. Follow the directions to the letter. The only exception is that they call for a 3M product that is not readily available to wipe down the car. I substituted with 3M "Adhesive, Wax & Mark Remover." Worked like a charm.
Old Aug 9, 2006 | 06:08 AM
FL07THC's Avatar
Was it hard to get them straight?
Old Aug 9, 2006 | 03:41 PM
ghull's Avatar
ronr, can you post a picture of the finished result?
Old Aug 9, 2006 | 06:56 PM
Scooters's Avatar
I'm the one who posted the pix of the white ones.
We've had them for a couple of weeks and like them. In addition to a bit of protection, they add a bit of a line to the car.
I bought them over the web (I assume that several of the parts sites have them). http://www.toyotapartsdelivered.com/...t.cfm?design=9 . The regular 07 Camry ones are the same as the hybrid.
There is a template carfully hidden in the box. You use tape, I used painters edging tape, to mark the height from landmarks at the front and the back of the car. You then run another horizontal run of tape between the landmarks to act as a straight edge. You the apply the edging. It is just very high powered, automotive grade, double faced tape.
NOTE: The edge guards do not go in a line that is straight with the bottom of the doors. Follow the template instructions for measuring and you will do fine!
UWAdventurer
May 4, 2008 09:21 AM
nicst47
Dec 3, 2007 11:14 AM
08hybridok
Sep 16, 2007 08:02 AM
Scooters
Jul 30, 2006 05:20 PM
solar dad
Jul 26, 2005 03:11 PM
