anybody install se camry seats in camry hybrid?
Old May 7, 2010 | 01:42 PM
camrydan's Avatar
Default anybody install se camry seats in camry hybrid?
hello
i own a 2007 camry hybrid, looking at getting camry se leather seats, anybody done this?, or remove seats on a camry to see any problem with this?
thanks
dan
Old May 7, 2010 | 06:07 PM
GeorgiaHybrid's Avatar
Default Re: anybody install se camry seats in camry hybrid?
Dan,
You shouldn't have a problem other than possibly the seat heaters not working until you run the correct wiring harness, switches and circuits for them.
WARNING !!!! Make sure you understand how the airbags work and disconnect the battery for AT LEAST ONE MINUTE before unplugging the seats. Setting them off can RUIN YOUR DAY. If you have never done this before, ask someone for help.
Other than that, have fun.....
Old May 7, 2010 | 06:14 PM
camrydan's Avatar
hello
i disconnect the battery in the trunk, correct? i want the power seats to work, the heaters i am not concerned with.
i will be looking at the seats soon, i looked at my wiring for the car, i just want it to plug and work
thanks
dan
Old May 8, 2010 | 06:53 PM
Yep,
The battery in the trunk. Don't forget to make sure you have the radio code and if it is your wifes car, write down and re-set the station presets on the radio when you are done. The harness should work OK but if not, a simple jumper section using the the correct ends should be easy to fabricate.
ptung07
Jul 30, 2013 07:15 AM
rburt07
Apr 26, 2012 07:00 PM
jetttstream
Sep 28, 2011 06:47 AM
wiredup
Jul 15, 2009 07:40 AM
Wangofree
May 27, 2007 02:07 PM
