After 22 months, battery is toast
Old Apr 16, 2008 | 01:57 AM
rburt07's Avatar
Default Re: After 22 months, battery is toast
Your probably right. In the sleep mode like when the fob is motionless overnight at home.
Old Apr 16, 2008 | 07:27 AM
talmy's Avatar
I don't think there is any location in my house that meets this.
Originally Posted by haroldo
According to the manual
Keep key more than 3 feet from a:
  • TV
  • Personal Computer
  • Cellular phone or cordless phone recharger unit
  • Electric light stand
  • Fluorescent desk light
Old Apr 16, 2008 | 07:36 AM
mozman's Avatar
Originally Posted by rburt07
If your car is new, you shouldl see a miles per gallon increase after your first 5000 mile oil change. You can get a extra.......
(1 mpg) gain by changing to the 0W-20 full synthetic oil.
I hope so!
Thanks for the tips!!!
Old Apr 16, 2008 | 09:26 AM
Droid13's Avatar
HSD Organic Interface
Originally Posted by CJO2007CamryHyb
22 months is pretty darn good for the FOB battery. I would expect that it would last at least a year but that's almost 2 years.
In comparison, my Sienna is going to be 5 yrs old next month, and both (conventional) fobs are still on the original battery. I went by the dealer to get the battery replaced since I figured these fobs are expensive and I didn't want to be responsible for wrecking it trying to pop it open. They didn't have any on hand. They have never seen a battery in one of these fobs go dead before...
Old Apr 16, 2008 | 09:33 AM
mikieboyblue's Avatar
It sounds like your Sienna has a manual key. If so, it would make sense that a fob used for clicking buttons to lock/unlock would last much longer. Our fob has to constantly transmit. Right?
Old Apr 16, 2008 | 09:42 AM
haroldo's Avatar
Originally Posted by mikieboyblue
...Our fob has to constantly transmit. Right?
Yes, thus the power saving mode
BATTERY POWER SAVING
Both the vehicle and key transmitters are always sending signals to each other. To prevent battery drain, the smart key system is automatically deactivated in the following conditions:
  • If the electronic key is left outside of the vehicle and within the effective range of the entry function actuation area for more than 10 minutes.
  • If the door lock or unlock operation is not performed more than 2 weeks.
The key and the vehicle are communicating even while the vehicle is not being driven. Do not leave the key near the vehicle (within 2 m [7 ft.]).
The vehicle battery may drain if the vehicle is not used for a long period of time.
To prevent battery drain, disconnect the battery negative (−) terminal or disable the smart key system. (For details about disable the smart key system, see “DISABLING THE SMART KEY SYSTEM” in this Section.)
To reactivate the smart key system, perform any of the following:
(a) Press the lock button on the front outside door handle or trunk open button while carrying the electronic key.
(b) Perform a wireless remote control operation.
(c) Insert and turn the mechanical key in the keyhole of the driver’s door.
Old Apr 16, 2008 | 01:24 PM
FastMover's Avatar
Old Boomer Techie
Wink Re: After 22 months, battery is toast
Just guessing (although it's probably in the manual somewhere), but, the fob goes into 'sleep' mode under certain conditions, to preserve it's battery. I imagine that there is a signal emitted from these devices that the fob picks up and prevents it from going to sleep.
HINT: If your bedroom table is on a common wall with the garage that the car is in, I suggest you put your keys ACROSS the bedroom. If the fob is in range to the car, then it will not "sleep". It will sit there and respond to the cars interrogations all night long. My brother discharged his in only four months!
Old Apr 16, 2008 | 07:27 PM
and...duh...
Old Apr 17, 2008 | 09:03 AM
schmidtj's Avatar
Keeping Toyota Solvent
I believe the MFD has a warning message to warn you that the key fob battery is low. If you didn't get that you either didn't notice it or the battery just failed.
Old Apr 17, 2008 | 09:36 AM
haroldo's Avatar
I guess if we all invested 94 cents in a spare battery and kept them in that slot in the front of the arm rest compartment ("...oh, that's what that slot is for!"), we can (mercefully) put this thread to rest.
