Adjust timer on lights off
Old Dec 20, 2007 | 03:48 AM
haroldo's Avatar
Default Adjust timer on lights off
I leave the headlights set to AUTO, so the lights stay on (for approximately 20 seconds) when I lock the car.
I typically keep my keys in a zipped up in a pocket (I lock the car by pressing the lock button on either the inside or outside door handle lock buttons), so using the key to lock the door (and override the light timer) isn't always practicle.
Is there any way to set the time for lights to shut off to a shorter time (~5 seconds)?
I never feel comfortable that I properly shut the car down until I see the lights go off.
Old Dec 20, 2007 | 04:35 AM
tjq's Avatar
tjq
Default Re: Adjust timer on lights off
My method varies a bit from yours. Always run with lights fully on. After stopping to get out, open door and hit lock button. After leaving the TCH, hit the lock button on the fob (while in my pocket). Figure it saves 10 seconds on the battery.
tjq
Old Dec 20, 2007 | 05:00 AM
haroldo's Avatar
Originally Posted by tjq
...After leaving the TCH, hit the lock button on the fob (while in my pocket)....
Sure, if the fob is accessible, but I keep it in a pocket that is zipped shut and if it's cold and wearing gloves or carrying something, it isn't a good option. I don't mind seeing the lights go from on to off, since it tells me I did it correctly. I'd prefer a shorter time frame.
Old Dec 20, 2007 | 06:28 AM
rmorrow's Avatar
According to the iguide, the delay time can be set to any of 30 seconds, 60 seconds, 90 seconds, or 0. The default is apparently 30 (although mine seems longer - I have to time it).
Old Dec 20, 2007 | 06:41 AM
To D Lake's Avatar
I'm not positive, but I believe I read that the dealer needs to program the change. So if you're going to take it in for that, look at the other things that can be changed ( all doors unlocked when you touch the driver's side handle, etc...) so that you have it customized to your liking all at once.
Old Dec 20, 2007 | 07:25 AM
mikieboyblue's Avatar
Yes this is true. The dealer must make this change. The second change (unlocking all doors by touch of handle) is something we can do. There are instructions in the iguide or the user's guide.
Old Dec 20, 2007 | 07:51 AM
haroldo's Avatar
Thanks!
I saw that this was a 'dealer' modification, but wondered if any of the tinkerers here knew how to do it (...turn car on, put in neutral, open glove compartment, turn wiper on, put A/C on recirculate and hold the map light button for seven seconds to adjust the light timer)
Old Dec 20, 2007 | 11:03 AM
jay_man2's Avatar
Beyond AM. Beyond FM.
If the manual says the dealer has to do it, they have a box they hook to the car to do it. And on that last one you forgot "rub your belly clockwise while patting your head every quarter second..."
Old Dec 20, 2007 | 12:24 PM
acco20's Avatar
Whew................ I had it going until that belly head thingy......
Old Dec 21, 2007 | 05:36 AM
McGyver's Avatar
I changed it to "ALL UNLOCK" by myself. Forgot the details, but it's in the manual.
