AC Power
Old Jun 1, 2008 | 06:01 PM
loosehead's Avatar
Default AC Power
I have a Belkin AC Anywhere DC to AC converter, used with my former vehicle. We're getting ready to head to Colorado and want to be able to recharge the laptop, etc. Is there any issue with using one of these with the hybrid?
Thanks!
Old Jun 1, 2008 | 06:07 PM
cngrevolution's Avatar
Default Re: AC Power
I would not think so. I am a realtor and I have a laser printer/copier in my trunk and a 400 watt inverter hooked to the 12 volt battery in the trunk. It works great! I just turn it on whenever I need to use my printer otherwise I just leave it off. If you use a small one like a 200 watt inverter that plugs into the cig. lighter then you should be fine to charge a laptop or other small item. If you use an inverter that hooks to the 12 volt batt. just make sure you turn the inverter off otherwise you might run down your batt. If you use a small one that plugs into the cig lighter then nothing to worry about as they turn off when you turn the car off.
Motown
General EV Discussion
17
Jul 21, 2016 03:09 AM
lars-ss
Off Topic
Jan 24, 2010 07:48 PM
mastersgtbob
16
May 31, 2005 07:09 PM
blueskies
Dec 21, 2004 06:36 PM
