6.1 VS 7.1 Nav Disk
Old Apr 13, 2008 | 04:30 AM
schmidtj's Avatar
Keeping Toyota Solvent
Default Re: 6.1 VS 7.1 Nav Disk
Originally Posted by delao13
Do you mean you don't have to press the OK button to get the warnings to go away?
Correct. The downside is you CAN't make the message go away sooner by pressing a button. You have to wait until it decides to remove the message. Several seconds but sometimes having to wait can be an annoyance.
Old Apr 24, 2008 | 09:10 AM
mlarma's Avatar
TCH Obsessive
I have a nice disc that I paid a bit for, but it is the old firmware so I can override and the 8.0 data. It's da-bomb.
Old Apr 24, 2008 | 09:15 AM
schmidtj's Avatar
When did 8 come out?
Old Apr 24, 2008 | 09:25 AM
backupguy's Avatar
My 2009 TCH came with 7.1. I assume it is the latest, unless the sales guy just gave me the wrong DVD.
Actually, I really miss my TomTom. The Tom Tom would always change the Map direction so I could easily see that left turns are left and right turns are right. With the TCH, a Right turn might be up or down relative to the screen.
Old Apr 24, 2008 | 09:26 AM
mlarma's Avatar
TCH Obsessive
Dunno...look on eBay. That's where I got mine. It was like 75 bucks or something....
Old Apr 24, 2008 | 09:33 AM
mikieboyblue's Avatar
You have to change the map orientation. Click on the compass icon in the upper left of the screen (map). When it displaces a "N" that means the top of the map will always be north. When it displays just two triangles (think one is red and the other white) the top of the map will be where you are heading...thus making the right turn be on the right.
Old Apr 24, 2008 | 09:39 AM
schmidtj's Avatar
Easily fixed. Just tap the compass rose in the upper left corner and instead of north up it will be your driving direction up.
Old Apr 24, 2008 | 10:51 AM
backupguy's Avatar
Thanks for this great tip. The Nav map screen is really confusing compared to tom tom and I am sure it will take a long time before I understand it all.
Old Apr 24, 2008 | 10:59 AM
schmidtj's Avatar
You should have received a Navigation Supplement with your TCH. If you purchased it new go beat on your salesperson to get one. Otherwise everything discussed is in there.
Old Apr 24, 2008 | 06:37 PM
KC Rusty's Avatar
I also bought the "8.0" release off ebay. Works fine and has all the over rides, however the seller must be a smart teckie who changed the DVD version to say dvd 8.0, but if get into the secondary service screens - the maps are still 7.x..
there isn't a true 8.x release as far as my research shows, but I've been known to be wrong before. Made a backup copy and it works fine also... Found more streets the 6.x I had
Better but than the big $$ Toyota wants
