2010 toyota camry wont start
Old Sep 18, 2015 | 08:02 AM
enilowo's Avatar
Default 2010 toyota camry wont start
Hi Guys,
I urgently need your help. Due to the fact that i wont be around i removed the battery terminal. A month after when i came back i plugged the battery back but the car wont start. The ready check wont come up but the lights are up the horn works.
Please help i am scared.
Regards.
Old Sep 18, 2015 | 05:36 PM
ukrkoz's Avatar
Default Re: 2010 toyota camry wont start
You discharged traction battery. 12 V battery has NONE to do with actual engine crank. It's traction battery that does this. This is why Toyota says to start engine every other week to keep traction battery charged.
Tow her to dealer and have them recharge the battery. It's $150 I believe. It is what it is.
Next time, have someone trusted to show up and either start the car till all battery bars are green or drive around till same accomplished.
Old Sep 21, 2015 | 11:19 AM
GeorgiaHybrid's Avatar
One thing of note, your 12 volt (not your traction) battery has to have enough voltage to boot the computers. If it discharged while undone, you could have the situation you describe where the lights will come on but not have sufficient voltage to boot the onboard systems. Have someone check and charge (if necessary) the 12 volt battery. If that battery is OK as is, You will need to dig a little deeper.
Old Sep 27, 2015 | 07:37 AM
ukrkoz's Avatar
12V traction battery?
Old Sep 27, 2015 | 06:51 PM
That's what I get for answering something after a few glasses of wine with dinner...
Meant to say "not your" in between... It is fixed now...
You manage to catch every screw up I make... And I make a BUNCH of them... Nice catch.
Old Sep 28, 2015 | 08:40 PM
ukrkoz's Avatar
You know why I like you a lot? You are very helpful AND never get upset.
I am a stickler, David. Comes with work. Besides, everyone is so confused on **** hybrids anyway, no need to add more.
You are a great guy, David. Much appreciated having you here.
Or, and just me being me. Golden forums rule is - never post if you had a drink.
cody07hch
Aug 18, 2019 09:11 PM
stotta87
Dec 27, 2016 11:24 AM
ngoll96
Nov 14, 2015 10:40 AM
Pete Ben
Ford Motor Company
Apr 20, 2013 05:38 PM
2k3 Mach
Apr 9, 2011 10:03 AM
