2007 Camry Hybrid Eco-Cool
Old Jun 14, 2018 | 11:07 AM
RefrigerationGuy's Avatar
Default 2007 Camry Hybrid Eco-Cool
hello,
i was was wondering if someone could help me with what may be going on. I may end up having to take it to Toyota to have them look at it. My car seems tor run like normal with the eco cool mode on, but if my air conditioning is low (so no eco) my battery seems to drain fast and the charging system has a hard time recharging it. My car will be delayed when beginning from a stop and feel rough. This has to be due to the battery being low because it runs great when it is charged. The battery also seems to charge once it gets low (in the eco mode) without a problem. Could something be over amping ? What does the eco button actually do? I’ve been unable to locate a valuable schematic. Thanks! Any advice is appreciated
Old Jun 14, 2018 | 10:45 PM
Default Re: 2007 Camry Hybrid Eco-Cool
Toyota.com for owners manual to tell you what eco does.
Everything you describe is symptomatic of a deteriorated hybrid battery - simply a loss of usable capacity. A NEW battery can only run the A/C full blast for about 4-5 minutes in most situations.
The rough start may be associated with a dirty throttle body and MAF sensor. This is an issue on the Gen2 Prius, and I would suspect it's common on the Camry as well. Probably many youtube videos.
Old Jun 18, 2018 | 11:08 AM
hybrid veggie's Avatar
Still learning about the hybrid system - the traction battery powers the A/C compressor?
Old Jun 18, 2018 | 11:19 AM
The A/C compressor is 3-phase 200VAC powered - no belt/pulley. It is either powered by the HV battery or via the primary generator (MG1) that is driven by the ICE. During decels, it can technically also be powered by MG2 (the traction motor-generator) during regenerative braking.
Technically, it's powered by the High Voltage system, which can be HV battery, MG1 or MG2.
Most common scenarios:
Car stopped, ICE off, A/C running - HV battery
Car stopped, ICE off, A/C running - MG1
Car under regenerative breaking, ICE on or off, A/C running - MG2
The HV DC voltage is converted to 3-phase 200VAC (variable speed) in the inverter regardless of source, i.e., wherever the high voltage DC comes from, it gets converted to 3-phase VAC in the inverter for use in the compressor.
Based on my observations and approximations, the "full-blast" A/C ("LO" with max blower) load is about 2000W. Once the car is at the set temp, and it's just maintaining, the power load can be much lower.
panamapat
Mar 11, 2018 04:13 PM
philco782
Oct 30, 2017 08:22 PM
HyCAMBill
Jun 18, 2009 09:34 PM
the_thecat_hat
Dec 2, 2008 07:58 PM
badpelican
Dec 5, 2006 10:44 PM
