2007 Camry Hybrid Brake Fluid Flushing Bleeding
Old Jun 8, 2015 | 07:07 PM
ukrkoz's Avatar
Default Re: 2007 Camry Hybrid Brake Fluid Flushing Bleeding
Actually it's junk.
CD ROM that came with it has archive that 2 computers could not open.
Olde Version of software I downloaded from recommended site will NOT connect to my Camry, ignition in position I, II, or engine started. Does not matter.
So don't waste your time and nerve on it.
Old Jun 9, 2015 | 10:22 AM
netrunner's Avatar
Originally Posted by ukrkoz
Actually it's junk.
It sounds like you weren't get the USB driver on the CD installed properly so the Techstream software isn't able to talk to the OBDC device.
Old Jun 9, 2015 | 08:55 PM
ukrkoz's Avatar
Well daahh, can't install the driver as CD ROM can not be opened. Not the disk itself, the archive on CD either shows as empty or none of the programs I used will open it.
Seller unfortunately was no help. Posted in his ad, he said you can download s/w from www....... and Amazon erased half of the link, as usual, as links may not be posted. So he either gets s/w to me somehow or I send it back, already have it packed.
Old Dec 9, 2015 | 06:06 AM
orionman's Avatar
OK. So I got the tool, installed it and got it to connect to the car so all is good so far. However, it says to remove the ABS motor relays 1 and 2. Which ones are they referring to? The ABS 1 and ABS 2 relays or the ABS MTR1 and ABS MTR2 relays?
Old Dec 9, 2015 | 02:45 PM
litespeed's Avatar
Professor Emeritus
If I remember correctly those relays are right there behind the actuator on the passengers shock tower.
ukrkoz
Dec 6, 2013 09:48 AM
atob907
Dec 8, 2010 07:07 AM
lifespeed
Sep 3, 2008 06:23 PM
atikovi
Dec 22, 2006 11:40 AM
bigbearballs
Aug 29, 2005 12:18 PM
