2007 Camry Hybrid Brake Fluid Flushing Bleeding
Old May 25, 2015 | 09:45 AM
netrunner's Avatar
Default 2007 Camry Hybrid Brake Fluid Flushing Bleeding
I successfully flushed & bled my brake fluid yesterday using the Techstream software, which can be found for download on the Internet, and this connector from Amazon:
Amazon.com : Fotga Newest V8.00.034 MINI VCI for TOYOTA TIS Techstream Diagnostic Cable & Software : Toyota Mongoose Cable : Car Electronics Amazon.com : Fotga Newest V8.00.034 MINI VCI for TOYOTA TIS Techstream Diagnostic Cable & Software : Toyota Mongoose Cable : Car Electronics
The procedure was easy and straightforward if you have bled conventional brakes previously. In the Techstream software, you go into the ABS Utility and run the brake bleeding procedure and it tells you exactly what to do step by step. I was surprised how easy it was.
A few comments:
-My 2007 had never had the brake fluid flushed so I was expecting it to look terrible(dark). I was amazed that it actually looked pretty good. It was honey colored but after 8 years you would expect much worse--amazing and, no doubt, a result of the regenerative brakes keeping the brakes & fluid cool. In my other non-hybrid cars, which I flush every two or three years, the fluid looks much worse than what I took out of the Camry hybrid. Still, with the high cost of the hybrid brake components, it is financially dangerous to neglect changing the brake fluid on these cars.
-It took me exactly one quart to fully flush and I did not have any extra left.
-As with all vehicles, you will need an assistant to push the brake pedal when indicated.
bonus of the "dongle" & techstream software: I also changed some of the settings with the software for door unlock/lock, added a new key(bought on ebay for $80 since my wife lost hers.), changed the inverter coolant (you have to run the coolant pump with the techstream software to bleed the air out).
Old May 30, 2015 | 07:34 AM
ukrkoz's Avatar
Default Re: 2007 Camry Hybrid Brake Fluid Flushing Bleeding
So I have a question. What exactly IS included into that wonderful price of $23.99? As I read that ad several times and still don't get it. Is it cable itself? How much is software then?
As Techstream itself is roughly $ 6 0000.
https://techinfo.toyota.com/techInfo...sheettinfo.pdf
Old May 30, 2015 | 07:35 AM
ukrkoz's Avatar
OK, I see now. It's just connector. Mind sharing where you got TS s/w from? Assuming you have it loaded onto your laptop.
Old May 30, 2015 | 07:48 AM
ukrkoz's Avatar
Got the TS s/w. $FREE.
But how do I start it? Can't find the launcher.
Thank you
Old May 30, 2015 | 07:50 AM
netrunner's Avatar
http://blog.uobd2.net/toyota-tis-techstream-9-30-002-software-download/
Old May 30, 2015 | 10:13 AM
KenSoren's Avatar
Follow the link in the first post to Amazon and read the questions and reviews. Sounds interesting enough that I ordered one so I'll leave a post once I see what I get. The reviewers say you need to be computer literate to get it to work, and $25 dollars won't hurt too bad if it I can't get it to work. Plus Amazon usually has a good return policy so little risk of losing any money.
Old May 30, 2015 | 12:53 PM
ukrkoz's Avatar
I found launcher too. It simply placed quick start button on my desktop.
So it so far appears to be functioning OK.
I'll t-fer s/w onto a laptop later and post too.
Not that I really need to do bleeding, BF is crystal clear, but I'm that type of guy - I like stuff like this.
Come to think, I have 11 pin OBD2 cable from my CAN BUS scanner. My laptop also has 11pin. I may just go that route.
Old Jun 2, 2015 | 08:11 PM
ukrkoz's Avatar
OK, got laptop, got TSI on it, ordered cable. Will have some to play with next weekend.
Old Jun 6, 2015 | 10:42 AM
litespeed's Avatar
Professor Emeritus
Originally Posted by netrunner
I successfully flushed & bled my brake fluid yesterday using the Techstream software, which can be found for download on the Internet, and this connector from Amazon: Amazon.com : Fotga Newest V8.00.034 MINI VCI for TOYOTA TIS Techstream Diagnostic Cable & Software : Toyota Mongoose Cable : Car Electronics
A few comments:
Good info. and thanks for posting.
Did you ever have your brake fluid reservoir replaced by the dealer? There is a campaign out to replace the reservoir free of charge. There is a filter between the 2 chambers and it can become clogged.
They did not bleed the brakes. But, that portion of the fluid was replaced.
Old Jun 7, 2015 | 12:13 PM
netrunner's Avatar
I did not accept this recall. I don't think it is necessary unless you have old brake fluid which has begun to form precipitates.
