2007 Camry HV errors
Old Mar 29, 2018 | 01:38 PM
Jeremy tech's Avatar
Default 2007 Camry HV errors
Check Hybrid system and check VSC
I get the following DTC codes
Hybrid Control P3107 Lost communication with airbag
ABS/VSC/TRAC C1252 Brake Booster on long time
C1256 Accumulator Low Pressure
C1345
SRS Airbag B1608 Front satellite sensor Bus Installation Error(CH)
Cleared all DTC codes and still get P3107, C1256 c1345
Has anyone else seen these errors or know the solution
thanks
Old Mar 30, 2018 | 11:54 AM
Default Re: 2007 Camry HV errors
Update installed actuator fixed braking issues.
Low pressure code is gone.
working on clearing vsc error and check hybrid system.
still got airbag code
Old Mar 30, 2018 | 08:22 PM
Load test 12V
Is your scanner a cheapo or high end?
Old Mar 31, 2018 | 05:11 AM
Tech stream version 12.10.19
laptop version
Old Mar 31, 2018 | 07:13 AM
Went to advance put battery on tester.
12.8 volts
527 cca
looks like factory battery.
Runs/drives fine brakes work like they should. Although lots of indicators will not reset.
Only DTC Faults present
P3107-214 airbag connection.
and the tire sensor which I haven’t fixed yet.
indicator on dash not showing Regen braking when stopping or charging, but the car is maintaining the charge levels of the battery. As all 17 modules are between 15.2 and 15.7 volts.
Dash indicators errors
check vcs and hybrid system check.
lights on are abs, abs slip, red exclamation, orange indicator, brake light and airbag.
Old Mar 31, 2018 | 08:15 AM
P3107-214 is probably the gremlin. Repair Manual indicates:
1) Wire harness or connector
2) Center airbag sensor assembly
3) Hybrid vehicle control ECU
Check for continuity between pin 14 on the Center airbag sensor assembly and pin 73 of the Hybrid control ECU
Old Mar 31, 2018 | 08:17 AM
Replace the airbag Ecu or check the plug.
where is the darn thing?
Old Mar 31, 2018 | 08:21 AM
Attached
File Type: pdf
Old Mar 31, 2018 | 08:23 AM
B1608 is likely secondary to the P3107:
Instrument panel wire
Engine room main wire
Front airbag sensor LH
Though they both may be pointing to the Center airbag sensor assy.
Old Mar 31, 2018 | 08:25 AM
I am online with car now notice the c1345 linear solenoid valve offset learning undone. On as well.
