2007 Camry HV errors
Check Hybrid system and check VSC I get the following DTC codes Hybrid Control P3107 Lost communication with airbag ABS/VSC/TRAC C1252 Brake Booster on long time C1256 Accumulator Low Pressure C1345 SRS Airbag B1608 Front satellite sensor Bus Installation Error(CH) Cleared all DTC codes and still get P3107, C1256 c1345 Has anyone else seen these errors or know the solution thanks |
Re: 2007 Camry HV errors
Update installed actuator fixed braking issues. Low pressure code is gone. working on clearing vsc error and check hybrid system. still got airbag code |
Originally Posted by Jeremy tech
(Post 265174)
Update installed actuator fixed braking issues. Low pressure code is gone. working on clearing vsc error and check hybrid system. still got airbag code Is your scanner a cheapo or high end? |
Tech stream version 12.10.19 laptop version |
Went to advance put battery on tester. 12.8 volts 527 cca looks like factory battery. Runs/drives fine brakes work like they should. Although lots of indicators will not reset. Only DTC Faults present P3107-214 airbag connection. and the tire sensor which I haven’t fixed yet. SRS Airbag B1608 Front satellite sensor Bus Installation Error(CH indicator on dash not showing Regen braking when stopping or charging, but the car is maintaining the charge levels of the battery. As all 17 modules are between 15.2 and 15.7 volts. Dash indicators errors check vcs and hybrid system check. lights on are abs, abs slip, red exclamation, orange indicator, brake light and airbag. |
P3107-214 is probably the gremlin. Repair Manual indicates:
1) Wire harness or connector 2) Center airbag sensor assembly 3) Hybrid vehicle control ECU Check for continuity between pin 14 on the Center airbag sensor assembly and pin 73 of the Hybrid control ECU |
Replace the airbag Ecu or check the plug. where is the darn thing? |
1 Attachment(s)
Attached
B1608 is likely secondary to the P3107:
Instrument panel wire Engine room main wire Front airbag sensor LH Center airbag sensor assembly Though they both may be pointing to the Center airbag sensor assy. |
I am online with car now notice the c1345 linear solenoid valve offset learning undone. On as well. |
