12v battery dead , need your help for a test
Old Feb 21, 2009 | 06:10 AM
pgnyc's Avatar
Default 12v battery dead , need your help for a test
hi !
i found my car not starting, i did not use it, for 3 days.
i test the 12v , i got 0.3V ==> dead.
can you test this :
push the start button 2 times -> radio off
try to leave the car and lock the door , can you do it ?
just to see if i left the car for 3 days on accessory mode !!!
thank you
ps: i checked, no front top light on ( was on door), no back top light on
Old Feb 22, 2009 | 08:40 PM
rburt07's Avatar
Default Re: 12v battery dead , need your help for a test
The dash lights, car heater fan and heat if it's set to High temp runs from the 12 volt battery. Headlamps, running and tail lights, ECU and engine ignition are included.
Make sure your Clock Light is Off anytime you get out of the car. The clock light idea is from someone in the group.
ukrkoz
Jul 15, 2012 10:05 AM
DebbieKatz
Feb 2, 2012 03:16 PM
flutiefan
Sep 18, 2011 09:23 PM
srockgibson
Apr 20, 2011 11:50 AM
Exido
Nov 25, 2007 06:33 PM
