07 camry no run, shows codes p3233 & u0110
Old Aug 7, 2017 | 08:31 PM
jtuchol's Avatar
Angry 07 camry no run, shows codes p3233 & u0110
bought car non-running from a auction talked to former owners they had it into dealer they pulled codes ( I have the cut sheet from dealer) they pulled these codes p3233 &u0110 which I looked up & I can tell what they say but to make a long story short it says to check the wiring, replace the inverter, & or the hybrid ecu. I did both of those & and still the same codes & no run still the other issue is I have 3 smart keys only one will work if you hold it up to the start switch, but it will work out side the car to unlock the doors. & I know what everybody going to say check the 12v THAT is new & I keep the battery charger hooked up to keep the voltage up when I am trouble shooting it. & battery in the fob is new too. other 2 fobs don't work at all. ( don't know if they are even for the car)
I am stuck don't know what else to do.
Old Aug 7, 2017 | 08:48 PM
Default Re: 07 camry no run, shows codes p3233 & u0110
Check all the fuses?
From your other forum post, 240V is dead for the HV battery. Nominal is 244.8V. A NiMH battery resting at or below nominal is at 0% SoC.
I've had 12V batteries go bad right out of the box. I'll believe you when you tell me you've load tested the battery at 100A for 15 seconds, and it holds 10.5V.
Old Aug 8, 2017 | 09:43 AM
jtuchol's Avatar
yea, I am checking all of the fuse's now the most easiest ones battery is good I had the monitor hooked up & battery charger when I did the scan 12v OK, I just bought a camry ( hybrid) wiring book for it trying to read & understand all of the points to understand it. I would like to find the camry (hybrid) shop manual to buy or down load for to figure out sequence of operation to try and go from there. having a hard time finding that!
Old Aug 8, 2017 | 09:57 AM
http://techinfo.toyota.com You can buy a short term subscription to the entirety of the shop manuals.
mgblues
Jun 4, 2015 02:06 PM
jimmy1
Jan 18, 2014 06:26 PM
HacksawMark
Nov 18, 2012 05:39 PM
vioarc
Aug 10, 2010 09:04 AM
