2009-2012 Escape Brake Simulator c1012
Old Mar 17, 2026 | 05:44 AM
irad's Avatar
Default 2009-2012 Escape Brake Simulator c1012
What type of screws and size held the simulator to the brake assembly, ie torx, allen, security? Is the hole near the spring a weep hole? Has anyone disassembled the simulator unit?
Here is the simulator, credit hippo the hybrid.
Old Mar 17, 2026 | 03:11 PM
Hippo the Hybrid's Avatar
Default Re: 2009-2012 Escape Brake Simulator c1012
Old Mar 17, 2026 | 03:18 PM
I can't answer your questions except that no, the old defective one was not taken apart. The old fasteners were probably reused. In our case, the power brakes were not lost but the illusion of having power brakes was lost so it was difficult, actually very difficult to brake. As you know, most of the braking is done through the regeneration mode and the actual hydraulic brakes play a secondary role in normal, non emergency braking.. To be comfortable driving a hybrid, the manufacturer has to create a subsystem that makes the braking force appear "normal". Part of that system involves a brake pedal feel sensor which is the part instrumental shown above that allows the driver to feel that the brakes are operating with a feel similar to a non hydrid or non ev vehicle.
Old Mar 17, 2026 | 03:22 PM
If you look at my brake pedal feel sensor post a couple of years ago, there are 3 long mounting bolts seen. Unfortunately the head type are difficult to discern their type.
Old Mar 17, 2026 | 04:15 PM
irad's Avatar
I tried zooming the bolts in your picture and I also could not tell. I'm thinking of drilling a hole near the top and squirting electronics cleaner into the simulator. Any thoughts?
Thanks,
Ira
Old Mar 27, 2026 | 02:21 PM
irad's Avatar
Bolt heads are torx PLUS t30 tamper proof.
Hippo the Hybrid
Nov 15, 2025 09:14 AM
Jacquelyn Marie
Jan 13, 2018 05:49 AM
wptski
Jan 14, 2011 01:14 PM
H2O Doctor
May 19, 2008 05:51 PM
Delta Flyer
Oct 28, 2006 02:24 PM
