08 Escape SSN Hybrid Bat NO CRANK NO START
Old Today, 12:26 AM
artemis91's Avatar
Unhappy 08 Escape SSN Hybrid Bat NO CRANK NO START
Hello everybody!
First post on here, so let me just say that I am extremely grateful to know that there's a community like this where people help others, and I hope that someday, somehow, I may return the favor.
I have a 2008 FEH with 205,011 miles. I let my dad use it for a few months and there were a few stretches where he didn't use it for days. He'd turn it on for roughly 10 minutes, but not drive it. While i was still using
it, I noticed that the car was barely taking off from a complete stop. At the same time, I noticed that the hybrid battery (HB) wasn't charging when I was braking, or at idle. After about 20 minutes of driving, everything started working as usual. Fast forward to the last month: I changed some suspension parts and when I went to turn the car on to take it for a test drive, the SSN message comes up, the car wont crank AT ALL, and the CEL is flashing for a few seconds.
Using Forscan, these are the codes that came up:
At this point, something (forscan) was telling me that my 12V might be bad lol. Voltage on the HB was in the 280s. I brought my 12V back to Sams Club who wouldn't replace it because "its not bad", so they recharged it and sent me on my way. I hooked up the 12V AND took jumper cables and hooked up the 12V to a running car, just to be safe. With the my 12V hooked up the to jumper cables to a running car, I pressed the "jump start switch" and let it do its thing. I did 3 or 4 cycles with the jump start switch and I only got up to 324, which theoretically, SHOULD have been enough juice to jump start the HB. Now, after scrolling through forums, I think the reason for the no-start is because my BSOC is at 0..
__________________________________________________ __________________________________________________ _
At least a lot of the codes that showed up the first time around were all gone. These are the ones that were still up after I cleared them:
===TCM DTC P0A0A-FF===
Code: P0A0A - High Voltage System Inter-lock Circuit
===PCM DTC P1000-FF===
Code: P1000 - On-Board Diagnostic (OBD) Systems Readiness Test Not Complete
===PCM DTC P1A10-FF===
Code: P1A10 - Hybrid Powertrain Control Module - Battery Disabled
===PCM DTC P1A14-FF===
Code: P1A14 - Hybrid Powertrain Control Module - Transmission Disabled
===BCM DTC B2172-60===
Code: B2172 - Inertia Switch Input Circuit Open
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
===IC DTC U2511-60===
Code: U2511 - CAN communication bus fault
Status:
Along with these, i ran a test on the BCM and I got the following:
P0A81- Hybrid Battery Pack Cooling Fan Control Circuit (did not show up in the DTC list)
P0A96- Hybrid Battery Pack Cooling Fan 2 Control Circuit (did not show up in the DTC list)
B2172- Inertia Switch Input Circuit Open (showed up in DTC list)
I then shorted the battery cables, with little effect (with the exception of a few new codes):
***NEW*** ===PCM DTC P0685-FF===
Code: P0685 - ECM/PCM Power Relay Control Circuit/Open
===IC DTC U2511-20===
Status:
- Previously Set DTC - Not Present at Time of Request
Module: Instrument Cluster
***NEW*** ===IC DTC U2023-60===
Code: U2023 - Fault Received from External Node
Status:
Diagnostic Trouble Code details
This DTC may be caused by :
Short circuit on the CAN line.
Open circuit on the CAN line.
There is a time out between two modules on the CAN bus
There is Interference on the CAN bus
There may be other modules on the CAN communication data line that are not communicating and are timing out.
***NEW*** ==ACM DTC U0193-20===
Code: U0193 - Lost Communication With Digital Audio Control Module A
Status:
I want to BURN this thing to the ground. Where should I start tackling this thing? Take out the battery and charge the cells like some mention in other posts? There are NO burnt fuses (that I was able to see). I'll try uploading a video of what I'm seeing when I go to turn it over.
Any help would be greatly appreciated!!
Hippo the Hybrid
08-21-2023 07:26 PM
Mtartt
05-12-2023 06:55 AM
stotta87
12-27-2016 11:24 AM
FredGRN
06-27-2015 07:50 PM
05CFL
02-12-2013 09:58 PM
Quick Reply: 08 Escape SSN Hybrid Bat NO CRANK NO START
