2009 Escape Hybrid No Start No Crank
Old Jul 21, 2019 | 05:08 AM
Mtartt's Avatar
Default 2009 Escape Hybrid No Start No Crank
Recently purchased a 2009 FEH from auction, replaced the 12V battery. instrument panel reflects the wrench and triangle of death with the following Forscan codes:
P0A1F- Battery Energy Control Module Performance
P1A10- Hybrid Powertrain Control Module Battery Disabled
P0A1F Battery Energy Control Module
Any assistance will be greatly appreciated.
Old Jul 21, 2019 | 10:26 AM
Hippo the Hybrid's Avatar
Default Re: 2009 Escape Hybrid No Start No Crank
I am not knowledgeable enough to decipher those but can you run tests on the modules in Forscan and display the results? Eg PCM (powertrain) Module, BCM (HV battery) module? That would provide more info on things like SOC state of charge etc.....
Old Jul 22, 2019 | 06:45 PM
Use Forscan to pull the SoC and HV battery voltage from the BCM. Post here.
Old Jul 22, 2019 | 07:03 PM
Mtartt's Avatar
Good evening S Keith Due to Codes P1A10 and P0A7D I truly believe the issue is the HV Battery. I have reviewed both your post regarding building a rudimentary charger 22 Sep 18 FEH (Reconditioning) and 25 Dec 16 (HV Battery Jump). If you could provide a point of clarification to a neophyte it would be greatly appreciated.
Post from 25 Dec 16 states "LPC-150-350 power supply will charge 350mA. 3-4 hours should be enough to get your pack to a state that is safe to start the ICE. For a battery that is very low, I wouldn't be concerned about as much as 12 hours of charging provided you're checking it for warmth every 30 minutes or so after the 8 hour mark. This is extremely conservative. I put in quite a bit more than that at higher currents and never felt any heat at all. To protect the power supply from the battery, you should install 2X 1N4005G diodes in the output lines. The positive lead should have the diode stripe on the battery side of the connection, and the negative lad should have the diode strip on the power supply side of the connection."
Your post on 22 Sep 18 outlines the addition of parts 709-APC35-350, a fuse holder, and only one diode on the positive output lead with the stripe on the battery side.
Anyway, if you understand that opening, tempering with or modifying a FEH/MMH battery has a risk of fatality, here's what you need to build a rudimentary charger:
https://www.mouser.com/ProductDetail/709-LPC100-350
https://www.mouser.com/ProductDetail/709-APC35-350
Wire the inputs in parallel (both fed from the same 110V source)
Wire the outputs in series to get UP TO 386V of 350mA current
Install fuse holder in one of the AC input lines. Install a suitable 6x30 250VAC 2A fuse in holder.
Install a diode in the positive output lead with the stripe on the battery side
Remove battery.
Remove forward cover.
Remove computer: where exactly is this connection located?
Remove Relay: Is this the relay that is flipped upside down?
thanks for all you do for our Hybrid community it really mean a lot!
Old Jul 22, 2019 | 07:06 PM
You appear to have copy/pasted my post rather than linking, and mixed your questions in there. A little confusing.
https://www.greenhybrid.com/forums/f...tioning-31765/
Once the battery is open, the instructions+pictures will be obvious.
Before you embark on this, Forscan SoC and HV battery voltage?
Old Jul 22, 2019 | 07:21 PM
Mtartt's Avatar
Sorry but your post offer two different solutions:
Option #1
LPC-150-350 and 2X 1N4005G diodes
Option #2
LPC100-350
APC35-350
Fuse holder
1 diode in the positive output lead with the stripe on the battery side
Also you mentioned removing the computer, where is the location?
Again thanks in advance.
Old Jul 22, 2019 | 07:23 PM
https://www.greenhybrid.com/forums/f...17/#post268382
Old Jul 25, 2019 | 06:03 PM
Mtartt's Avatar
S. Keith for clarification
Two Diodes One on the (+) battery side and one on the AC (-) side?
Thanks for your support!
Old Jul 25, 2019 | 06:09 PM
Old Jun 29, 2020 | 02:16 PM
tposs001's Avatar
I was able to pigtail the battery, and have a solid reading, so that connection works:
This is the connector I used:
Can someone guide me as to what to do with the 3 cables on AC side of the HLG-120H-C350 power supply? What do I connect those two in my cannibalized extension cord?
