09 feh C1014 and bubbles in rear brakes
So changed front sticking calipers and front brake lines. Did standard brake bleed battery disconnected. Was good at first. Then started throwing codes, pedal to floor. Ignition recycle would come back. Bought pressure bleeder and i keep getting bubbles from rear. Tried foscan but dosent show system bleed only abs bleed. Tried and no luck, put qrt through rear brakes and still getting bubbles. Any ideas?
thanksjc
06-11-2013 05:48 AM
