Off Topic Politics, life, gadgets, people... gobbledygook.
Possible code bug?
Old Feb 18, 2004 | 07:08 AM
JackC's Avatar
Jason
I think you might need a "site discussion area" or something! hopefully, it will remain small...
Anyway - I found what might be a small bug.
I added a post in your SAT area quoting an earlier post by you.
In the Post area (the quote area was below, as normal), I entered the first paragraph of test. I followed that with a blank line, then the further line:
"for jkash...""
What happened on the post was that the "jkash" line appeared inside YOUR quote, along with my sig - and your name appeared OUTSIDE of the quote, along with my first paragraph as normal.
How very wierd. I did not take a screen shot and actually would like to try again shortly - but ahve run out of time today.
Been Very Busy lately here. Haven't been around as much as I would like! Keep up the great work!
Jack
Old Feb 18, 2004 | 01:09 PM
Jason's Avatar
Site Founder
Not sure what you mean. You must type [ quote] (no space) to start and [ /quote] to end. You must use both.
in
out
Code:
[QUOTE]in[/QUOTE]
out
Old Feb 18, 2004 | 01:26 PM
JackC's Avatar
Yeah - and I haven't been able to repeat it either. Hmm.. At least, not yet.
When I quote a previous post, the quote appears below in a seperate area. I have this nice big area to write my own note in. I don't necessarily have to manually add the quote denotations.
In this at least one case, I wrote my note as usual, posted it and found that my second paragraph and sig were actually contained in the original quote! It was really wierd.
I thought about leaving it for you just so you could see it, but then, figured it must be easy to repeat - only it isn't.
Maybe I will go back to the original note and try it again, just to see what happens!
Jack
Old Feb 18, 2004 | 01:33 PM
Jason's Avatar
Site Founder
Sounds like you didn't add a closing quote tag.
Old Feb 19, 2004 | 05:11 AM
JackC's Avatar
Well, see, that's the POINT! I didn't add ANY tags - the system does this for me. It was after I posted the message and saw the results that I saw what had happened. It was wierd.
But, it hasn't happened again, so :blink:
Jack
Old Feb 19, 2004 | 11:43 AM
Jason's Avatar
Site Founder
If you hite the [QUOTE] button in the reply area accidentally, it could account for it
RPCV36
Feb 10, 2006 01:04 PM
Jason
Jun 9, 2004 01:05 AM
