Jason
I think you might need a "site discussion area" or something! hopefully, it will remain small... Anyway - I found what might be a small bug. I added a post in your SAT area quoting an earlier post by you. In the Post area (the quote area was below, as normal), I entered the first paragraph of test. I followed that with a blank line, then the further line: "for jkash..."" What happened on the post was that the "jkash" line appeared inside YOUR quote, along with my sig - and your name appeared OUTSIDE of the quote, along with my first paragraph as normal. How very wierd. I did not take a screen shot and actually would like to try again shortly - but ahve run out of time today. Been Very Busy lately here. Haven't been around as much as I would like! Keep up the great work! Jack |
Not sure what you mean. You must type [ quote] (no space) to start and [ /quote] to end. You must use both.
in Code:
Not sure what you mean. You must type [ quote] (no space) to start and [ /quote] to end. You must use both. |
Yeah - and I haven't been able to repeat it either. Hmm.. At least, not yet.
When I quote a previous post, the quote appears below in a seperate area. I have this nice big area to write my own note in. I don't necessarily have to manually add the quote denotations. In this at least one case, I wrote my note as usual, posted it and found that my second paragraph and sig were actually contained in the original quote! It was really wierd. I thought about leaving it for you just so you could see it, but then, figured it must be easy to repeat - only it isn't. Maybe I will go back to the original note and try it again, just to see what happens! Jack |
Sounds like you didn't add a closing quote tag.
Originally posted by Jason@Feb 18th 2004 @ 4:33 PM Sounds like you didn't add a closing quote tag. But, it hasn't happened again, so :blink: Jack |
If you hite the [QUOTE] button in the reply area accidentally, it could account for it :)
