NAH - Battery Voltage Meter
Old May 13, 2010 | 10:41 AM
cbabkirk's Avatar
Hybrid Enthusiast
Default NAH - Battery Voltage Meter
My Altima is a 2009. In the almost one year of ownership, I have never seen the EV battery indicator read above 3/4 percent full. I have seen it almost on empty. No amout of coasting, breaking, or slow driving will get that meter above 3/4 percent full. Is this typical? Seems we are lossing out on some extended EV miles because we always start out at 75% battery capacity before the engine needs to kick in to charge things back up.
-Cliff
Old May 14, 2010 | 04:54 AM
cephraim's Avatar
Default Re: NAH - Battery Voltage Meter
If I coast down a long, steep hill, I get it to probably 90% full. If I brake at the bottom, it's nearly pegged full.
Old May 14, 2010 | 06:28 AM
langjie's Avatar
+1. it won't go over 75% under normal conditions, but braking down hills, slowing down on the highway for tolls, it'll go above that but you use up the extra charge really quickly
Old May 14, 2010 | 07:14 AM
cbabkirk's Avatar
Hybrid Enthusiast
Not too many hills around where I usually drive so not sure I can push this to read higher than 75% before it starts getting used up again. Maybe that's my normal.......thanks.
Old May 14, 2010 | 08:24 AM
langjie's Avatar
it is normal. doesn't make a lot of sense for the engine to charge the battery to 100%, else you would never be able to recapture braking energy
Escape_from_Hanover
Feb 16, 2009 12:27 PM
Hybrid_SUV
Jan 26, 2009 12:02 PM
cobalt293
Dec 15, 2007 10:48 AM
Everest
Nov 3, 2006 01:40 PM
