Musty odor from the A/C
Old May 12, 2009 | 06:01 PM
stephen431's Avatar
Default Musty odor from the A/C
Anyone else getting this issue? It just started about a week ago. A musty / mildew smell from the A/C. It goes away when I put the airflow on recirculate or run the fan without the A/C.
Old May 13, 2009 | 07:41 AM
langjie's Avatar
Default Re: Musty odor from the A/C
i've had this happen with pretty much every car. when you have the A/C running for awhile and then turn it off, it will have a funky smell for a little bit and then turn back to normal. I'm thinking this has something to do with having your vent walls collect water when you turn off the A/C.
Old Aug 19, 2009 | 05:03 PM
2008es350's Avatar
the solution that i found Frigi-Clean and Frigi-Fresh. I found it from a couple of forums like Toyotanation and IH8tMUD and SilvaradoSS. I got it a www.ac-evaporator-cleaner.com
Old Aug 20, 2009 | 02:11 PM
Yosemitesam's Avatar
Please see my thread (Yosemitesam) with pretty much the same question. I am thinking of contacting the factory.
Sue M
Mar 7, 2010 02:28 AM
VietVet'67
Aug 23, 2009 07:55 AM
ntguru
Jan 3, 2009 05:17 PM
LEAKYTCH
May 19, 2007 12:17 PM
reza
Mar 30, 2007 09:35 AM
