Interior Cabin Filter is a major PIA
Old Sep 8, 2010 | 08:42 AM
langjie's Avatar
Default Re: Interior Cabin Filter is a major PIA
Originally Posted by tomscot2
Do you remove the bolts and then slide the assembly out of the exterior of the vehicle? In other words you pull the assembly out from outside the trunk and then access the bulb, rather than access the bulb from a compartment/door on the interior side of the trunk?
You remove the bolts, pull off the assembly, and then you will have access to the bulbs on the assembly
dgyimao
Dec 31, 2009 09:38 AM
bugs
May 26, 2009 12:05 AM
stevenvillatoro
Dec 1, 2006 06:25 AM
nycspud
Nov 20, 2005 02:02 PM
cbxtc6
Dec 20, 2004 10:27 AM
