High RPM / Low MPG
Old Aug 21, 2019 | 01:47 PM
ht_dave's Avatar
Default High RPM / Low MPG
Hey all,
I've been having an issue with much lower than normal fuel economy lately in my 2008 NAH. I'd say I'm down 15-20% or so from normal. I've also noticed that the car seem to be running at what feels like a higher than normal RPM. I can watch the instant MPG display and I can let off the pedal and go back on and it will almost feel like it's "shifting" down a bit, but then it will jump back up.
Also, I had an issue where when I started the car, when cold, if I shifted into reverse (reverse is only electric) before the engine would start (to warm itself up), I would get a shaking for a few seconds. If i waited for the engine to start, no issues. I did change the air filter, PCV valve, and spark plugs. That issue seems to have gone away, but the MPG issue remains.
Old Aug 21, 2019 | 05:36 PM
Default Re: High RPM / Low MPG
Those symptoms can be typical of a hybrid battery on the verge of failure.
I would also check that none of your brakes are dragging.
Old Dec 16, 2021 | 10:30 AM
ht_dave's Avatar
I know it's been two years, but I realized that I never posted a followup. Due to covid, it took a while to sort out, but it turns out the problem was a failing ignition coil. #4 finally fully burned out (taking out a ECM fuse as well). Replacing it got things running good as new.
gpsman1
Mar 2, 2010 05:19 PM
tigertas32
Jun 19, 2009 05:36 AM
MrCrank
Dec 8, 2007 05:26 PM
felixdacat
Nov 15, 2006 04:04 PM
