Heating problem Nissan Altima Hybrid 2008
Old Jan 8, 2019 | 09:48 AM
older's Avatar
Default Heating problem Nissan Altima Hybrid 2008
Hello
I have a Nissan Altima Hybrid from 2008,90.000 miles.It is the only car imported in Romania in 2010, and I do not have a specialized service available.The problem is related to the heating system.In the EV MODE mode the heating is no longer working, basically the water pump does not circulate anymore and the thermal engine no longer receives the command to start to maintain the temperature of the high water.On the go, when the heat engine works, the heat is running, at the traffic light or in electric running, it no longer supplies the heat.It worked for a short period of time while I turned the temperature **** from hot to cold and vice versa afterwards did not want to start.Basically if I have the full battery and stay in place the car does not introduce heat.
Someone else has encountered this problem, some advice would be of great help.
Thank you in advance and "dry asphalt"
Old Jan 8, 2019 | 04:59 PM
Default Re: Heating problem Nissan Altima Hybrid 2008
The only source of heat in the Nissan Altima Hybrid is the gas engine.
Normal operation for heat is to run the gas engine as required to meet the heat demand regardless of EV mode or not.
I don't know why you are having this problem. I have never heard of it. It is worth doing all the basics:
Check for trouble codes.
Check fuses
Confirm you have enough coolant
hlv
Apr 20, 2013 04:45 PM
stevejust
Nov 27, 2007 02:15 PM
malibucarl
46
Jun 18, 2007 01:54 PM
GalacticFattPatt
Jul 24, 2006 05:54 PM
