Dead Battery Experience
Old Aug 4, 2008 | 11:18 AM
  #41
cephraim's Avatar
Default Re: Dead Battery Experience
Bump. Anyone know the answer on the potential use of the 12v chargers through the lighter plug?
Old Aug 4, 2008 | 11:48 AM
  #42
steved28's Avatar
Given that the 12V outlets are non operative when the car is off, I would say no.
Old Aug 4, 2008 | 04:12 PM
  #43
lloyd123's Avatar
The 12V power outlet at the bottom of the storage compartment between the front seats is always live even with the ignition off.
The 12V outlet in the storage bin in front of the shifter is a switched power supply.
At least in my NAH which doesn't have the NAV system.
Old Aug 4, 2008 | 06:06 PM
  #44
cephraim's Avatar
But, I don't think it matters whether it's on or not, as I will be CHARGING the battery through this outlet (current goes the opposite way), right?
Old Aug 4, 2008 | 07:58 PM
  #45
steved28's Avatar
Yes, it matters. If the circuit is broken, it's broken in either direction. If you turn off a faucet in your house, water doesn't flow, doesn't matter which direction.
Old Aug 4, 2008 | 08:07 PM
  #46
steved28's Avatar
Then you might have a shot with this one. Personally I wouldn't charge a battery this way. You don't know what gauge wire is being used, and what is between it and the battery. These aren't the old cigarette lighters where they used heavy gauge wire and just about a direct line to the battery. There very well could be a diode which prevents a backfeed too. The only way to test it would be with an ammeter.
Old Aug 8, 2008 | 02:58 AM
  #47
townboy's Avatar
read your book... do not use your 12V(the one running on hybrid battery) while using AC.
MyPart
Mar 7, 2011 12:29 PM
phoebeisis
Honda Insight
Mar 14, 2006 06:01 AM
Jason
Dec 30, 2005 12:49 AM
kenny
Mar 28, 2005 05:00 PM
