08 NAH Techincal Service Bulletin?
Old Jul 24, 2008 | 06:43 AM
cephraim's Avatar
Default 08 NAH Techincal Service Bulletin?
I just found this TSB at the NHTSA site:
Make : NISSAN Model : ALTIMA HYBRID Year : 2008 Manufacturer : NISSAN NORTH AMERICA, INC. Service Bulletin Number : NTB08-044 Date of Bulletin : JUN 09, 2008 NHTSA Item Number : 10024942 Component : ELECTRICAL SYSTEM:BATTERY Summary :
2007-2008 ALTIMA HYBRID 12V BATTERY FOR SERVICE. *NJ
Anybody look into this yet?
Eph
Old Jul 24, 2008 | 08:41 AM
lloyd123's Avatar
Default Re: 08 NAH Techincal Service Bulletin?
http://x.nissanhelp.com/forums/Knowledgebase/links/341
You can access all the TSB's for the NAH at NissanHelp.com. You can register for free but are limited to one download per day or you can pay for unlimited downloads.
Edit - looks like they now allow two downloads per day for free.
Old Jul 24, 2008 | 01:12 PM
steved28's Avatar
****! I KNEW they should have been putting deep cycle 12V batteries in these things. This service bulletin is to replace you battery with an Optima battery.
Old Jul 25, 2008 | 07:58 AM
nicholus's Avatar
new to this forum - lots of nifty tips here.
Sort of a dumb question, but what sort of symptoms should someone look for if the 12V battery is dying/dead? Obviously, in a conventional car, the car wouldn't start. In a hybrid, the HV system has me confused. As I understand it, the HV battery powers the AC and even the stereo (through a HV-to-DC converter). So, what does the 12 battery do? Start the ICE? Help the power windows go up and down? Is that it?
Old Jul 25, 2008 | 04:30 PM
lloyd123's Avatar
The 12V battery runs most of the normal accessories that it would in a non-hybrid such as radio, lights, horn, blower fans, coils for the ICE spark plugs, engine cooling fan, all the electronic control systems like emissions and ABS, etc. I guess a sign it would be failing would be these systems not working properly. You could always test the battery with a load tester(?) There is a device that steps down the 245V DC to 12V DC to charge the regular battery.
I believe there is no HV-to-DC converter as the HV battery is 245V DC. That voltage goes to inverters located above the transaxle where it is converted into AC and higher voltage for the traction motors. I also believe the AC compressor is run directly by the 245V DC - at least it has some big orange cables going to it which means don't touch.
Old Jul 25, 2008 | 04:48 PM
lloyd123's Avatar
Here's a more detailed discription from the First Responders Guide for the NAH about the electrics:
The Low voltage system:
A 12 volt DC negative chassis ground body electrical system
The High voltage system:
A 245 volt DC high voltage battery
A harness that carries high voltage between the high voltage battery, converter, inverter unit, transaxle and electric air conditioning compressor
A converter which converts 245 volts DC to 42 volts DC for the electric power steering (EPS) system
A converter which converts 245 volts DC for charging the 12 volt battery
An inverter unit which delivers up to 650 volts AC to the transaxle
A transaxle which houses a traction motor and generator
A 245 volt DC, electric motor driven electric air conditioning compressor
Old Jul 25, 2008 | 05:37 PM
nicholus's Avatar
thanks much, Lloyd! not sure why I thought the stereo was on HV-12V...must have misunderstood something I read elsewhere. Really appreciate the recap!
Old Jul 26, 2008 | 11:45 AM
tomscot2's Avatar
Eph
Took my car in this morning for the one year service maintenance and asked for this battery replacement. It did not show up on the recall list for my VIN number. He said that if it wasn't on the printout based on my VIN number that it does not apply to my vehicle.
Old Jul 26, 2008 | 06:27 PM
nicholus's Avatar
It's not a recall. It's a service bulletin - meant to advise service techs. Basically it says that if the 12V battery ever goes bad, that it shouldn't be replaced with the same kind - but rather the updated model. Until your 12V battery goes bad, don't worry about it.
Old Jul 27, 2008 | 12:07 AM
tomscot2's Avatar
That is what they told me when I picked the car up. When the current battery dies, they will replace it with the different model.
