Engine turns over then stalls after 12v battery replacement
Old Apr 2, 2022 | 11:48 AM
gmamadog's Avatar
Default Engine turns over then stalls after 12v battery replacement
2009 Mariner Hybrid
I just replaced the 12v battery under the hood today and after replacement followed the instructions in manual to engage parking brake and turn off all accessories. When I started the vehicle it started fine then stalled after several seconds with a Stop Safely Now message. Had to wait about 10 min before it would start again but stalled with the same message. Both the throttle body and the EV battery were replaced last fall. Any ideas what could be causing this?
Old Apr 2, 2022 | 12:59 PM
Default Re: Engine turns over then stalls after 12v battery replacement
If it's only running for about 5-10 seconds, it's not actually running. That's the HV battery trying to spin the engine, but it's not firing. You should avoid multiple attempts to start until you isolate the issue. You can deplete your HV battery charge, and the 2009 doesn't have the HV jump starter.
Recommend you detach the supply line from the fuel rail and confirm you're getting fuel when you turn the ignition to the on position.
Fuel pump and fuel pump driver failures are not uncommon. I had to replace the fuel pump on my 2005.
Old Mar 27, 2024 | 11:50 AM
Originally Posted by chima lecci
I wonder how did you sort it out ?
Be honest. You truly don't give a ****.
andrew.y
Jul 17, 2018 04:32 AM
cowboy
Jul 29, 2012 07:36 PM
tja
Jan 7, 2012 08:05 AM
alaskansunbeam
Jul 24, 2010 06:15 PM
