Also replaced the Battery Fuse on the GS450H
Old Aug 4, 2011 | 11:03 AM
LexHybrid's Avatar
Default Also replaced the Battery Fuse on the GS450H
What's going on guys!
I would also like to add that the same customer's GS450H that I changed the Battery Cooling Blower on also had the battery fuse changed as well. Here's a quick write-up on that job:
--Reference material--
GS450H battery diagram
1) Disconnect the negative battery cable.
2) Remove the electric battery fuse as follows:
Release the 2 claws and remove the service plug grip cover.
Remove the 2 bolts and electric vehicle fuse.
--How to Install--
3) Install the electric vehicle fuse with the 2 bolts. Tighten the bolts to 48 inch. lbs. (5.4 Nm).
4) Install the service plug grip cover with the 2 craws.
5) Install the service plug grip.
6) Connect the negative battery cable.
7) Install the battery service hole cover.
That should just about cover it. If you need further assistance on accomplishing a specific step then just let me know!
Old Jan 2, 2012 | 05:49 AM
l8apex's Avatar
Default Re: Also replaced the Battery Fuse on the GS450H
swooshrc
Dec 13, 2015 09:08 PM
thejessman123
Apr 11, 2015 01:06 AM
LexHybrid
Lexus GS 450h
Aug 4, 2012 01:01 PM
tsvikabp
Lexus GS 450h
Jun 24, 2011 11:09 AM
talljetman2
Feb 16, 2009 12:56 PM
