Journalism & The Media Television, radio, movies, newspapers, magazines, the Internet and more.
What is it with the "hybrids are expensive and don't pay off" myth in the media?
Old Aug 10, 2006 | 10:45 PM
  #71
CaptainObvious's Avatar
Default Re: What is it with the "hybrids are expensive and don't pay off" myth in the media?
Originally Posted by Tim
Absolutely. This is why I think the econo-box comparison falls down. I get to drive a regular sized car, with decent power, respectable safety, with adequate options and comfort. It's a unique car that's put a bit of excitement in what would otherwise be a routine car owning experience. All that and 46 mpg. I also agree with your point that the media takes a very one dimensional view of the purchase decision.
I think Civic LX to Civic Hybrid is fair enough. I wouldn't compare a current Civic to an Echo... the Civic is clearly a cut above.
Old Aug 11, 2006 | 07:39 AM
  #72
Mr. Kite's Avatar
I'm sure you do. To use the Civic EX in a comparison would push the hybrid more towards the economical side and this is not what you want to do. You have always come across as being biased and I would expect nothing less.
Old Aug 11, 2006 | 08:20 AM
  #73
AshenGrey's Avatar
Hybrid True Believer
I used to own an Echo, and it's not like a HCH at all. My Echo had about 89 HP, manual windows, noisy/buzzy drive, no air bags, no antilock brakes, no power morrors, a cheesy paint job, and had relatively high maintenance costs. It was also uncomfortable for more than an hour drive, and internally small.
My HCH has power-everything, 110 HP, air bags, antilock brakes, is quiet and comfortable for a 6-7 hour drive.
These two cars just don't compare.
Old Aug 11, 2006 | 08:38 AM
  #74
lars-ss's Avatar
For sure, not an opinion but a fact - An Echo is LESS OF A CAR than any model Civic. FAR LESS of a car than the HCH.
Anyone who disbelieves that fact is not seeing Reality.
Old Aug 11, 2006 | 11:49 AM
  #75
Chilly's Avatar
Originally Posted by alan_in_tempe
Please reread my whole post and you will find that my Camry Hybrid will have paid for its additional initial cost before by next income tax filing, and within a year or two total if you ignore the tax credit. That is my situation based on the closest acceptable alternative that met my minimum requirements (a Camry XLE 6 cyl).
I will state this one last time, and then I will give up, because it doesn't appear my position is being misunderstood.
Also, the Camry 4 cyl and the Camry Hybrid do not have the identical ICE. The block is nearly identical, but the bore is different to allow the same compression ratio with the Atkinson valve timing (resulting in a greater expansion ratio). It is the Atkinson cycle that allows the engine to burn fuel with significantly less emissions, but does not add to the production cost (or CO2 emissions during production) of the engine (no additional or more complex components beyond the compression release mechanism for rapid starting, just different cam and stroke). To further improve the efficiency of the engine, the CVT allows operation to stay in optimum RPM ranges which are not appropriate to the Otto cycle version of the engine. Since the CVT is really a fixed ratio planetary power splitter which has no clutch or other frictional components, this tranny should be significantly more reliable than a conventional tranny with clutch and syncros (manual) or with torque converter and bands and clutch (auto). That is not to say the entire drive train is more reliable, but the components having more speculative reliability (electronics/batteries/motors) are covered under the 100K mile warranty.
You have said nothing here that I don't understand. But if you are trying to determine how much GAS SAVINGS a hybrid platform adds to and existing engine (knowing full well engine mods need to be made for optimum performance) than you need to compare the same base engine with and without the hybrid platform. Any other comparsons that are being made do not directly answer the question "How much does a hybrid save in gas". By comparing to the V6 you are answering the quest "How much did YOU save in gas with your purchas decision." There is a big distinction. Yes I understand that you would not have purchased the 4 cyl because of lack of power, that is irrelevant to the generic question. Your purchase decisions are only relevant to your particular case. To answer the question "How long does the it take for the Camry Hybrid to pay for itself in gas?" You need to compare the 2.4L DOHC 16V VVTi engine with and with the hybrid platform. Any other comparison is invalid.
It is reasonable for me to assume that this car is cheaper for me than the alternative in the short run, and even more so in the long run. My insurance is lower, my fuel costs are lower, my maintenance costs for the first 100K miles are most likely lower (if only for the brake pads!), and my trade value in probably six years (my average time with a car) is likely to be higher than the most similar non-hybrid vehicle I would have considered purchasing.
Again, I am not arguing any of these points. The only point I am arguing is regarding fuel cost vs hybrid cost. Insurance is irrelavant. Maitenance costs to 100K are an unknown. Trade in value is an unknown.
With that said, it is my firm belief that the overall CO2 and other pollutants associated with the production, use (the biggest total contributor), and termination of this vehicle is substantially less than the alternative XLE V6 model, and that happens to be the number one incentive I had for my purchase. However, in hind sight, the great pleasure I have operating this technological marvel is the best reason to own one! Saving fuel is a most exciting and pleasantly challenging sport that I never imagined I would enjoy pursuing, but I sure do.
-- Alan
Please go back and reread my posts as well. I think you will find I have agreed with you on all the points listed in this paragraph. I have tried to convey more than once that there are a million reasons why Hybrids are a viable option. I am not trying to convince anyone that they should not have purchased their hybrid. I am thrilled that you are pleased with your purchase. You should be!!! I know I have been thrilled with mine.
Old Aug 11, 2006 | 12:59 PM
  #76
Chilly's Avatar
One more quick point.
The V6 Camry is 268 hp with a 0-60 around 7 sec
The 4 cyl Camry is 158 hp with a 0-60 around 10 sec
The Hybrid is 187 hp with a 0-60 at 9.4 sec.
http://www.thecarconnection.com/Vehi...180.A9947.html
The TCH is closer much closer in performance to the 4 cyl than to the V6. Just one more reason why this is the more accurate comparison of these vehicles.
Old Aug 11, 2006 | 01:00 PM
  #77
Tim K's Avatar
Originally Posted by Chilly
Here are the links to the specs.
MMH
http://www.mercuryvehicles.com/marin...ifications.asp
MM
http://www.mercuryvehicles.com/mariner/models.asp
No but we are trying to give a fair comparison of vehicles, inorder to determine how long it will take to recoup the cost with gas savings. So comparing HP and acceleration times gives you a better indication of which model to compare the MMH to.
I believe the numbers above support my arguement.
The MMH has much closer performance numbers (8.9 secs) to the 4 cyl (9.1 sec) than to the V6 (8.1 sec).
The fact that the hybrid only adds .2 secs to the acceleration of the vehicle, along with the HP numbers, validates that the MMH performance is more comparable to the 4 cyl model, which is why those two models should be compared together if you are ONLY trying to determine the question of cost savings in gas.
Even though I disagree with the comparison, for arguments' sake I will go along with it anyway. Mercury, however only offers the 4cyl on its most basic model which is totaly stripped down so we can't really compare it. Ford does offer the option of a 4 or 6 cyl on the Escape, so I will use those numbers for my evaluation. The cost difference of the 4cyl and the 6cyl on the Escape is $855 (MSRP). So even taking that amount off the price of an identical Mariner with a V6 makes the "Hybrid Premium" less than $2000 after state and federal credits.
For the record, I didn't buy the Hybrid to save money, but it is nice to know that it isn't going to cost me any more money to produce less pollution and send less money to the middle east.
Old Aug 11, 2006 | 01:42 PM
  #78
Chilly's Avatar
I agree it is very very difficult to get a 1 to 1 comparision because hybrid trim levels do not always line up with what is available in a comparable non-hybrid version.
The only thing I would caution you with in your evaluation is not to use MSRP but True Market Values, which are a more reasonable estimation of what you would pay for the vehicle. Most Hybrids sellf or closer to MSRP, in general, and you can usually get most non-hybrids at values closer to invoice. This isn't always the case, and some people will get really go values on their Hybrids, I paid $300 over invoice for mine, but I believe the general rule of thumb should be to use TMV.
For the Escape according to Edmunds
FEH AWD (no options added) TMV = $27,780 (MSRP $27,845)
http://www.edmunds.com/new/2007/ford/escapehybrid/100726885/optionsresults.html?action=2
FE XLT AWD 4 -cyl (ALL options added) TMV = $24,467 (MSRP $27,040)
http://www.edmunds.com/new/2007/ford/escape/100726652/optionsresults.html?action=2
As you can see the Hybrid is much closer to MSRP than the non-hybrid. And this is comparing the most basic FEH to a full loaded XLT. The price difference is most likely even greater if I were to take the time to synchronize options as best as possible.
And for the record I also didn't by my hybrid to save money either. I bought it because it was the car I wanted and that really is all that matters in the end. I hope you are enjoying yours as much as I am mine.
Old Aug 11, 2006 | 02:03 PM
  #79
Mr. Kite's Avatar
The problem with using True Market Values is that they are artificially inflated for hybrids by tax credits and various other incentives. If you are going to use True Market Values, you need to at least include the tax credits. MSRP gives a better idea of what they would sell for without all of the incentives.
Old Aug 11, 2006 | 02:26 PM
  #80
Chilly's Avatar
I agree. When looking at the final cost for a Hybrid it should be TMV - Credits.
