Journalism & The Media Television, radio, movies, newspapers, magazines, the Internet and more.
Credible Tahoe report
Old Feb 23, 2008 | 07:02 PM
bwilson4web's Avatar
Engineering first
Talking Credible Tahoe report
http://www.freep.com/apps/pbcs.dll/a...802210312/1081
BY MARK PHELAN • FREE PRESS COLUMNIST • February 21, 2008
It's my job to be skeptical about the claims car companies make when they introduce new vehicles: to believe what I experience behind the wheel, not what the PowerPoint presentations and computer-enhanced commercials promise.
Skepticism is healthy, but I approached the 2008 Chevrolet Tahoe hybrid SUV with outright cynicism. My expectations were so low you'd need a pooper scooper to lift them.
GM's previous hybrids fostered that response. The vehicles felt like they were built out of a sense of obligation, not a drive to be best. Sure, as GM points out, they cost less than the hybrid systems pioneered by Ford, Honda and Toyota, but they broke no new ground, set no new standards and made no pretense to technical leadership or innovation.
I expected more of the same from the Tahoe.
Man, was I wrong. Not "Oops, my bad" wrong. I was the-world-is-flat, man-will-never-fly wrong.
I was 26.3-miles-per-gallon-in-three-ton-SUV wrong; and that's way wrong.
A nice review and what I've been looking for.
Bob Wilson
Old Feb 24, 2008 | 06:15 PM
Tochatihu's Avatar
Default Re: Credible Tahoe report
I appreciate the mention of the idea that it could save more fuel gallons (compared to the non-hybrid version), than a Prius (compared to...um I don't know, but tha's not the point).
It's completely correct though mathematically subtle that adding 5 mpg at 20 mpg matters more than adding 5 mpg at 50.
Our departed hero Dave Hermance made the same point in many public presentations.
We need to save fuel in all vehicle classes. Build the best ones you can! Buyers, choose the most economical vehicle that does what you need done.
Everything else is "styling".
DAS
Old Feb 25, 2008 | 06:46 AM
finman's Avatar
Prius geek
"GM calls the system a two-mode hybrid because it improves fuel economy both in city and highway driving. Other hybrid systems reduce fuel consumption in city driving, but have no effect at highway speeds.
The rear-drive hybrid Tahoe rated 21 m.p.g. in the city and 22 m.p.g. on the highway in EPA fuel economy tests. That compares with 14 m.p.g. city and 20 m.p.g. highway for a similar gasoline-only Tahoe."
Wrong. The Prius is fully ulitizing electricity all the time to further efficiency, even on highways. Duh.
And 22 MPG is certanly better than 20 MPG (highway), but at the expense of higher overall emissions? See the attched .pdf.
THAT is simply stupid.
And 50 grand for a marginally more efficient vehicle that is dirtier? who are these suckers who will buy this? How does this get into the hands of many, to really make a difference? A limited market with limited availability? Wow, and I thought it couldn't get any worse.
I'm sorry, but GM is laying yet another crap-brick. I'm just not a big fan and need to rant. YMMV.
File Type: pdf
Old Feb 25, 2008 | 11:30 PM
Tochatihu's Avatar
Tangential comment, and only to completely agree with Finman. The Prius electic CVT (which has many other names) allows the gasoline engine to be operated in (or darn near) its highest efficiency over a huge range of load and vehicle speed conditions. This is a major contribution to its overall efficiency.
Other hybrid (and 'hybrid') systems may do much less towards the goal. Or should I say The Goal.
DAS
Old Feb 26, 2008 | 06:39 AM
Sungod18's Avatar
Part Time Hybrids
With the exception of GM's hybrids I thought both Honda/Toyota systems currently feature highway savings features.
Just looking at my car:
1) Smaller engine that gas only version means more savings over the same distance travelled.
2) Fuel cutoff when gliding/coasting, works on the highway as well. The only gas only cars with fuel cutoff just reduce the # of cylinders active to 2 or 3.
Old Feb 26, 2008 | 06:20 PM
empowah's Avatar
Indeed, the reduced displacement, Atkinson cycle, CVT ratios, LRR tires, and improved aerodynamics of some hybrids improve highway fuel economy. GM's dual-mode system adds to that a planetary set of four fixed gears that provides a direct mechanical path for the electricity.
The Tahoe's additional 2 MPG on the highway is rare among heavier hybrids. With HSD on the LS and GS, highway fuel economy drops by 2 MPG.
Old Feb 26, 2008 | 06:34 PM
gumby's Avatar
Energy Independence
Yes.
Somehow this slips everyone's mind, but the numbers don't lie. You can look at driver results (like MINE, for example ), or just get EPA test results direct from the government.
http://www.fueleconomy.gov
Checking some out:
2008 Civic 4dr sedan:
Regular - 25 city/36 hwy
Hybrid - 40 city/45 hwy (no comparison!)
2008 Altima
Regular - 23 city/31 hwy
Hybrid - 35 city/33 hwy (close, but still better)
2008 Camry
Regular - 21 city/31 hwy
Hybrid - 33 city/34 hwy
2008 Highlander 4WD
Regular - 17 city/23 hwy
Hybrid - 27 city/25 hwy (quite close, but still better)
2008 Ford Escape FWD
Regular - 20 city/26 hwy
Hybrid - 34 city/30 hwy
2008 Ford Escape 4WD
Regular - 19 city/24 hwy
Hybrid - 29 city/27 hwy
HOW IS THAT NOT BETTER ON THE HIGHWAY?
Now it's certainly not AS MUCH % BETTER as is the CITY MPG. But to say there is no improvement is a LIE (except for maybe some of GM's offerings). I can only presume that nailing the gist of the (usually) limited improvement on the highway was the intent.
Old Feb 27, 2008 | 05:57 AM
caholla's Avatar
Hybrid Owner
I know everyone keeps looking at the highway numbers, but some of us urbanites do mostly city driving. I know there are a lot of SUV drivers out there who are driving them because of the 'cool' factor, but there are also individuals who have legitimate needs for such a vehicle.
At this point, the fact that an opportunity for improvement exists is a good thing. I'm not joining in the GM bashing.
To me, the ultimate hybrid would be a 15-passenger van, a minivan or a Suburban (filled with stuff of course). That truly maximizes the people/cargo per vehicle per mpg.
Old Mar 3, 2008 | 07:52 AM
kdhspyder's Avatar
From: Two miles N of the technology 'center-of-the-world' in 1903, on the Outer Banks of NC
IMO there should be no mud slung at GM on its first real entry into the Hybrid Derby. This technology is every bit as effective as Toyota's or Ford's or Honda's.
I've noted it here several times ( parrotted by the author as well ) that for an SUV driver this vehicle does save more fuel than moving from a Civic to an HCH or a Camry to a TCH. Remember no other vehicle makers has been able to make a 6000# hybrid yet. As noted previously it is far far more important to solve our biggest problem first; i.e. improving the least efficient vehicles. Much more fuel will be saved, less money will be spent and less emissions will be generated if we address SUVs and trucks as the primary problems today.
The two really important issues facing us as a driving population are improving the City driving mode of all vehicles ( the least efficient mode ) and improving the least efficient vehicles as a group. These first 2-Modes do both admirably. Both of these are far more important than increasing the Prius from 48 mpg to 60 mpg.
BTW the market for fuel prices will take care of the problem of too many 'image' owners of trucks and SUVs. Since the end of 2003 more than 1 million buyers annually have already 'parked' their gas guzzlers in favor of buying something more efficient. As fuel goes to $4 or $6 or $10 a gallon in the next 5-15 yrs these big rigs will naturally die out like dinosaurs. What will be left are those few big rigs that are needed imperatively. Those vehiclles will be very very efficient by today's standards ( 26-30 mpg? ).
Jason
Hybrid & Related News
Apr 2, 2005 10:15 PM
Jason
Our Announcements
Aug 29, 2004 07:16 PM
