Journalism & The Media Television, radio, movies, newspapers, magazines, the Internet and more.
CNN: Customized 250mpg Plug-in Prius
Old Aug 15, 2005 | 10:21 AM
Delta Flyer's Avatar
Banned
Default CNN: Customized 250mpg Plug-in Prius
An electrical engineer has added batteries to his Prius and gets up to 250 mpg. I'd bet they are discounting the fuel used for his additional batteries.
CNN Story
Old Aug 15, 2005 | 02:39 PM
Schwa's Avatar
Default Re: CNN: Customized 250mpg Plug-in Prius
"They're like the hot rodders of yesterday who did everything to soup up their cars. It was all about horsepower and bling-bling, lots of chrome and accessories," said Cindy Knight, a Toyota spokeswoman. "Maybe the hot rodders of tomorrow are the people who want to get in there and see what they can do about increasing fuel economy."
Old Aug 16, 2005 | 08:14 AM
MGBGT's Avatar
As I have posted elsewhere labeling such a plug-in as getting 250 mpg is a mis-statement of fact, IMHO. A better way of stating what such a car 'gets' would be:
50 mpg + 200 extra miles on initial charge. After the plugged in battery is exhausted, thsi car has to lug around a greater mass than a non-plug-in, and thus would get reduced mileage.
Old Aug 25, 2005 | 09:36 AM
AshenGrey's Avatar
Hybrid True Believer
So... Does this mean that if someone drives less than 200 miles per day and doesn't drive fast, the car won't ever use any fuel? That would be cool if it worked out that way!
Old Aug 25, 2005 | 10:04 AM
Schwa's Avatar
More like 20 miles per day, but yes basically no gasoline needs to be burned.
Old Aug 25, 2005 | 11:38 AM
clett's Avatar
The EnergyCS Prius is not a full "gasoline-optional" hybrid. The "assist" range of the larger battery is 50-60 miles, during which range gasoline usage is dramatically reduced but not eliminated completely.
This is because at any speed above 34 mph the gasoline-engine must kick in (for technical reasons, not due to any limitation in battery or motor power output).
In the unlikely event that you needed to travel a long way with low acceleration and at all times below 34 mph, then it should be possible to travel about 40-50 miles before any gasoline is used in EV mode only. (after the battery is depleted the gasoline-engine must switch on, at which time the car reverts to behaving like a normal Prius).
tesluv
Tesla
Oct 27, 2020 04:23 PM
Jason
May 17, 2005 12:12 PM
Jason
Apr 28, 2005 07:46 PM
lars-ss
Apr 5, 2005 01:46 PM
