Hybrid & Related News New cars, press releases, articles and more. Reply only. Have news?
Popularity of gas-electric cars surges as Honda unveils improved Civic Hybrid
Old Oct 31, 2005 | 04:15 PM
xcel's Avatar
Default Re: Popularity of gas-electric cars surges as Honda unveils improved Civic Hybrid
Hi Moosh:
Originally Posted by moosh
The 2006 HCH is electric-only when at 35MPH or below. That means I'll be driving 34MPH in a 35 speed limit. Sorry tailgaters!
___With at most a useable .5kWh pack, spun up ICE, and live electronics all the while in EV, you won’t be doing 34 mph in EV mode for very long, that is a guarantee … Another of Honda’s screw ups to get it out on the road instead of designing IMA properly in the first place.
___Good Luck
___Wayne R. Gerdes
Old Oct 31, 2005 | 08:37 PM
tanstaafl14's Avatar
As Jar Jar Binks would say, "How wude!"
Old Nov 1, 2005 | 06:09 AM
moosh's Avatar
Owner
You'd think with the fourth generation they might get it right. Seeing how I can't build a car, I'll have to go with what Honda has to offer. I like the added torque and electric-only mode.
I'm hoping for a PHEV mod sometime in the future. This is the first Honda that has the ability to run on electric only, so I have to assume that the mod has a good chance of happening. Hopefully CalCars or some other group will come up with the technology to replace the batteries and battery control computer for the HCH.
Old Nov 1, 2005 | 08:10 AM
lkewin's Avatar
Owner of '06 HCH #7264
Moosh - You list your hybrids as "2006 Honda Civic Hybrid" How you do that?
Old Nov 1, 2005 | 08:40 AM
moosh's Avatar
Owner
I typed "2006 Honda Civic Hybrid" in the Hybrids section in my profile. I also added my car to the Mileage Database, which you can do from the Mileage Database section of the website.
Old Nov 1, 2005 | 08:44 AM
xcel's Avatar
Hi Moosh:
___I do not know if you understand how an IMA based Honda’s MGSet is mated to the ICE’s output. If IMA could run separate via clutch based torque converter or whatever and had a much larger and more robust pack, IMA would be a kick-@$$ system the likes that could not be duplicated at any price. Since the MGSet and ICE cannot spin independently, an 06 HCH-II converted to a PHEV won’t do anything but show how inefficient an IMA based hybrid is when running in a pure EV mode. CalCars would not give a second thought to an 06 Civic PHEV let alone wasting their time and your $’s on the conversion due to IMA’s lack of independence from that of the ICE. If Honda does not fix this ICE/MGSet dependence in their next IMA reiteration, Toyota, Ford, and whoever else will own the automotive world. HSD/eCVT only needs a fix of its MG1/ICE spin up dependence after 41 mph and they will kill the Honda’s of any type in the FE arena at even higher speeds.
___Good Luck
___Wayne R. Gerdes
Old Nov 1, 2005 | 09:09 AM
AshenGrey's Avatar
Hybrid True Believer
I would guess that the current HCH'06 design was a compromise between "mild" and "full" hybrid. There is a HUGE advantage to the "mild" design: if the battery dies (ie. left the lights on, etc), the car is immediately drivable on gasoline-only after a jump-start.
Maybe there should be a new classification: "three-quarter hybrids", since the HCH'06 is more than "mild", but I wouldn't call a car with a 90 second EV mode exactly a "full" hybrid either.
I think the new design is pretty cool.
Old Nov 1, 2005 | 09:17 AM
AshenGrey's Avatar
Of course, people forget that you can also make the FE better by making the ICE more efficienct. Apparently, Honda just announced a new engine technology called HCCI that burns fuel 30% more efficiently. If you put that enging into a HCH'06, you'd get 65 MPG, without having to change the IMA at all. here's the link:
http://www.hybridcars.com/blogs/hyview/hcci
Old Nov 1, 2005 | 02:12 PM
AZCivic's Avatar
Conservative Socialist
HCCI is technology that every car maker wishes they could do. Ford made a lot of noise about HCCI in their lab about 6 months ago claiming it was more efficient and much cleaner than even high pressure common rail diesel. The big problem with HCCI is that it's so hard to make it work, even in the lab where you control all the variables. In theory, something as simple as a mass air meter sensor going out of calibration, or the intake air temp sensor being wrong for a split second could lead to the destruction of the engine.
http://en.wikipedia.org/wiki/HCCI
Old Nov 2, 2005 | 08:22 PM
moosh's Avatar
Owner
Does anyone know what the most efficient pulse and glide technique is for the '06 HCH? I'm guessing slowly accelerating to 35 then decelerating to 30 and repeat?
Also, what does FAS stand for?
