Honda Motor Company/Acura Honda hybrids
Hey all, question about IMA light and smog test
Old Dec 6, 2017 | 11:33 AM
gabecvega's Avatar
Default Hey all, question about IMA light and smog test
Hey all,
I recently purchases a 2002 Honda Civic Hybrid with the IMA light on. There were no other lights on.
I diden't think this was too big a deal since the car still gets decent mpgs.
I just found out that this IMA light may prevent me from passing smog.
Can anybody tell me if the IMA light is a barrier to passing their smog test in the state of California?
It doesn't make sense to me since the battery should not have anything to do with emissions output but I cannot be sure.
Could someone please advise me?
Thank you.
Old Dec 6, 2017 | 04:20 PM
Default Re: Hey all, question about IMA light and smog test
There is no such thing as a 2002 Honda Civic Hybrid. It's possible you have a 2003 that was manufactured in late 2002.
In the state of CA, a seller is legally obligated to provide a smog certificate.
If the IMA light is on, the check engine light is on. If the check engine light isn't on, the check engine light bulb may be burned out. There are some rare cases where you get IMA without CEL. Whatever the case, you should drive to the nearest O'Reilly auto parts store to have your codes read.
The battery is a component of the hybrid system. The hybrid system is a component of the emissions system. If a component of the emissions system fails, you can't pass emissions.
Think of it this way - if a failed battery prevents the car from getting the rated mpg, then it is impacting emissions. It doesn't matter that the mpgs are "decent". It's not getting rated mpgs based on EPA tests.
Old Jun 15, 2019 | 07:22 PM
jjh1's Avatar
I have figured out a way to get rid of the IMA battery codes and allow the system reset so there is no sign of messing with them and give about a 30 mile window to get the car inspected.
Old Jun 15, 2019 | 07:24 PM
https://www.greenhybrid.com/forums/f...tml#post268230
Old Jun 18, 2019 | 05:47 PM
hybrid442's Avatar
Hey Keith,sorry to see you shut down your pm,,we chat on the other forum,,but am try pass smog in Maryland and am getting the 1449 code. And o420 pending code,,both go off about 5 miles after resetting the 12 volt,,any help would be great,,,I don't have a charger on this car,,have a Genesis one charger but no harness for 2003 civic,,harness is on the insight,,also try get a harness made to be able to discharge the battery,,any help would be a great help.thank you
Old Jun 18, 2019 | 07:05 PM
Replace your cat or get an anti-fouler plug.
Replace battery or get a harness for the HCH and grid charge. Discharging without charging to full first is a GREAT way to kill a battery.
Old Oct 18, 2019 | 11:27 AM
CCWhite's Avatar
please tell me how
Alih00001
Mar 8, 2019 05:23 PM
LevisJeanz
Apr 12, 2017 12:45 PM
hpatel18
Sep 22, 2016 03:39 PM
cazort
Oct 28, 2013 08:07 PM
SidewinderX
Mar 4, 2011 06:49 PM
