insight tires
Old May 31, 2005 | 05:13 PM
oldsnail's Avatar
Default Re: insight tires
yah, i cant find tires that cheap... i even have costco's coupon book for the summer wich doesnt have any tire sales..
165/65/14 for 109CDN is pretty steep.. my high performance summer tires dont even cost that much.
i plan to get 175/65/14 falken 512 for 69CDN, even though it doesnt utilize the cars full utilty, in the long run, it would save...
ideaology is:
for the non stock spec tires - since i pay less for tires, i estimate pumping 1-2 litres more at the pump..with more grip.. and the tires are 160CDN cheaper than stock while buying 4.. $160 is alot of liters
stock size and brand tires - the stock size is that i would pay alot for tires, and use factory output of fuel..
Old May 31, 2005 | 06:21 PM
ericbecky's Avatar
Contributor ($)
I'm pretty sure that if I hadn't found a good deal on the tires, I would have switched to a different brand that wasn't low rolling resistance.
Old Jun 21, 2005 | 02:06 PM
Lbvaughan's Avatar
I was at first daunted by the prices of the Bridgestone tires and the lack of availablilty.
However I discovered that Les Schwab makes thier own tire in that size and it is substantially cheaper than the same tire from the other manufacturer.
http://www.lesschwab.com/tires.html
Old Jun 22, 2005 | 07:20 PM
xcel's Avatar
Hi Lbvaughan:
___About all I can add is you really want to be careful for what you wish for in regards to replacement tires for the Insight. Those that have switched to larger, sticker, or off-brand tires usually do receive improved traction and less tram-lining but they take a huge hit in the FE department and the strain placed on the pack just shortens the life of the vehicle that much more.
___Just a warning and one that some may want to take careful consideration of is all.
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
Old Jun 25, 2005 | 02:29 PM
JeffKinTN's Avatar
Hypermiler
Tire Rack was at $48 a tire for a long time. The are up to $54 a tire now.
Old Jun 27, 2005 | 04:38 PM
oldsnail's Avatar
so has anyhere used 175 width tires on the insight?
if so, does it require the removal of the rear panels for regular use?
thianks
Old Jun 27, 2005 | 06:10 PM
HafNHaf's Avatar
i'm running 175/65/14 sumitomos. no problems at all.
andy g.
Old Jun 28, 2005 | 06:11 PM
oldsnail's Avatar
thanks.. even the 175 size is back ordered.. should be getting them next week
Old Sep 12, 2011 | 07:36 AM
ascotmascot's Avatar
So it sounds like there isn't a clearance problem with going with larger 175/65R14 tires for the Honda Insight. Kumho makes a Solus HM KR22 in this larger size that is designated as a LRR (Low Rolling Resistance) tire. Will this tire give me comparable MPG ratings as the OEM Bridgestone Potenza RE92's?
TonyInsight
Honda Insight
May 5, 2011 04:25 AM
insighthopeful
Honda Insight
May 1, 2008 10:22 AM
Rick in Yuma
Honda Insight
22
Feb 28, 2008 01:33 PM
TheGreenMachine
Honda Insight
May 25, 2006 07:54 AM
Sledge
Honda Insight
May 25, 2006 07:48 AM
