insight tires
Old May 27, 2005 | 04:41 AM
oldsnail's Avatar
Default insight tires
the stock 165/65/14 bridestone is almost gone, and i think they arent so great to begin with and are pricey for 14's. . so i plan to look for other tires. i also noticed that nearly no other tire makers make this size, so i was wondering if anyone tried to put something a bit wider?
i was thinking 175/65/14.. but not sure if the rears will rub..feedback plz.
Old May 27, 2005 | 09:20 AM
ericbecky's Avatar
Contributor ($)
Default Re: insight tires
Insight tires are a bit pricy. Do have a Costo in your area? They tend to have the best deals. You can always check tirerack.com as well.
Old May 27, 2005 | 12:07 PM
oldsnail's Avatar
but has anyone used the width 175 vs the stock 165 width? coz the stock ones realyl suck.
Old May 27, 2005 | 01:00 PM
ericbecky's Avatar
Contributor ($)
Yes, people have used 175/65/R-14s without having rubbing problems.
Whatever you choose will likely decrease your mpg slightly since they won't be Low Rolling Resistance tires. But you will have more choices in handling characteristics.
Old May 27, 2005 | 04:07 PM
xcel's Avatar
Hi Oldsnail:
___The Bridgestone RE92’s are actually inexpensive the last time I looked. IIRC, you can pick them up from Costco for something like $46.00 + mounting and balancing? I can find the exact number if you like but it can be found with a google search or over at Insightcentral.net.
___As far as the mileage hit, oh boy. Are you pushing for max mileage or just kind of starting her up and driving with your FCD meters turned off? If you drive for the former, anything but the RE92’s will take at least 5 mpg off you tally and that is being kind. If you drive like the latter, about what Eric mentioned. You should receive better wet traction, better dry traction, and better handling with another brand tire but an Insight was designed for one purpose and that was maximum FE. The OEM tires selected are part of the design and a change to it will cost you in some respects.
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
Old May 27, 2005 | 05:08 PM
oldsnail's Avatar
thanks for the reply, i live in western canada.. we have lots of rain here. and in winter, snow. summer is short lived. so i was hoping something with a bit of traction would pay off in the safety department.
i was thinking of getting Falken ziex 512 @ 175/65/14 size priced at $69CDN a peice
Old May 28, 2005 | 05:02 AM
oldsnail's Avatar
EDIT: cotsco sells the stock size for 109CDN + tire tax and 14% tax a peice
Old May 29, 2005 | 07:08 PM
oldsnail's Avatar
xcel, can u please tell me where u can purchase the stock tire for $46, even if it is USD, its still not bad. thanks
Old May 29, 2005 | 07:49 PM
ericbecky's Avatar
Contributor ($)
Usually they have a sale at least once a year where you get $60 for a set of tires.
Here's a quote from my previous experience buying tires in January 2005.
They were having their "$60 off a set of tires sale" but for some reason the price of the tire only showed $48.99 per tire in my online shopping cart, instead of the regular $59.99 per tire price that is shown in the tire description page? Not sure why it showed up this low.
Basically I just took it as a buy 3 get one free deal and didn't worry about the "missing" $20. It was still a good deal.
I could have called customer service to try to get the extra $20 but didn't. I figured they might want to change the "error" of the $48.99 price and try to change it back to $59.99.
In any case, here is the Costco tire price I got when checking on their site.
I went to the Costco Website and it came up as total price as
$226.57 installed.
Here's the breakdown:
Per tire
$48.99 tire
$1.00 disposal fee
$10.00 installation package
$2.50 State fee (your state may not have this)
Multiply this by four and you get...
$249.96 subtotal
Add
$12.48 Non-member surcharge
$13.12 Tax
subtract ($48.99) Coupon - (this automatically showed up)
$226.57 ORDER TOTAL
There is not a Costco near me so I took the Web Page print out to a
local Tires Plus that has a set of tires in stock and they PRICE
MATCHED! Good deal, since Tires Plus originally wanted $81.62 PER
TIRE installed. (before tax)
For the price match deal it worked out, before tax, to be $53.36 per
tire installed! ($226.57 - $13.12 = 213.45. Divide by 4 equals 53.36)
Old May 30, 2005 | 10:26 AM
xcel's Avatar
Hi Oldsnail:
___What he said
___Thanks Eric.
___Good Luck
___Wayne R. Gerdes
