Wheel Tech Question.
Old Aug 15, 2005 | 09:55 AM
BigBill's Avatar
Default Re: Wheel Tech Question.
Originally Posted by Tim
BigBill,
Thanks for asking this questions - I've had the same one. I've found 15" rims that are 10 lbs (OZ Superleggera), but I really like these Centerlines (I like the Storm and RPM). Question - do you know the difference between chrome and polished mirror finish? Was wondering why one was more expensive.
Also, have you done any looking into the impacts of different wheel diameter on the Hybrid? I'm assuming that if stock is 185/70R14, then 195/60R15, 205/50R16, etc. are all roughly equivalent. True?
The chrome is more expensive since its more expensive to manufacture.
Chrome wheels are also heavier.
Tire sizes, 3 things play a role. Rolling resistance and tire width (These two are closely related) and overall height.
Stock is 185/70/14
195/60/15 .1% and 205/50/16 is .8% so both are close.
If the overall tire height and overall wheel and tire weight are the same, It will not have an impact on FE or a very small one, due to the roling resistance.
Old Aug 15, 2005 | 10:09 AM
Tim's Avatar
Tim
Enchanter, Enthusiast
Thanks - I found on the web confirmation that the stock weight of the wheel and tire are about 31 lbs. I was thinking of uping to a 15" and 195/60 (for looks, but keep the FE impact down). Even with a 15 lb tire and those 10 lb rims I found, that's only 26 lbs - 5 lbs overall on each wheel. Seems like that wouldn't make a whole lot of difference. If I can't improve the FE I may not bother with the expense. However I'm close to needing new tires, so I thought I might as well go for something that looks nicer.
Have you done much research on tire selection? I've tried to research low rolling resistance tires but haven't found much. Don't know if they even make them in 195 or 205. Was curious what brand you were considering.
Old Aug 15, 2005 | 07:43 PM
AZCivic's Avatar
Conservative Socialist
If you go with 195/60-15's, I'd suggest the Sumitomo HTR 200's. They're only $43 each from Tire Rack and were rated one of the lowest rolling resistance tires in the Green Seal March 2003 report. I've run about 6 different sets of tires on my Civic (I used to autocross a lot and wear out tires very fast) and my Sumitomo HTR-Z's were my favorite. If the HTR 200 is even close to the HTR-Z, then it should still be a very quiet, grippy tire while having a low price, generous 380 treadwear rating, and rated as a top pick for low rolling resistance.
Oh, and one final note on the HTR 200 - it's rated 51psi max according to the specifications. Most tires carry a 44psi max, but this one specifically shows a 51psi max. That would also be useful to a hypermiler to know they can run 50psi totally safely and within the manufacturer specifications for the tire.
Old Aug 16, 2005 | 09:27 AM
Tim's Avatar
Tim
Thanks! Appreciate the feedback. Rolling Resistance info is hard to find - I can only find that report when I looked too. I wanted to keep at 195 or less - just to keep the FE impact at a minimum.
Curated Content Editor
May 8, 2014 05:00 AM
67fastback
Mar 24, 2014 01:23 PM
ucla54
Nov 28, 2009 12:15 AM
MrBond
Jan 2, 2007 05:11 PM
MagneticPearl06
Feb 6, 2006 09:01 PM
