What tires did your Honda Hybrid come with?
Old Aug 13, 2007 | 09:13 AM
livvie's Avatar
Default Re: What tires did your Honda Hybrid come with?
If anything you sense understeer. Which is what most car manufacturer design into the car. It's the easiest thing to correct, let off the gas. Especially a front drive non-sports car like the HCH I.
Old Aug 18, 2007 | 08:59 AM
OlympicDreams's Avatar
Bridgestone Insignia SE200-02
44 PSI
Old Mar 23, 2009 | 07:32 AM
montana41's Avatar
Angry Re: What tires did your Honda Hybrid come with?
My OEM were the Dunlops, just replaced them (at 36K) with the Bridgestones Insig SE200 because they where $50 cheaper each, however, Im seeing a decrease in milage 0f 37-38mpg where I previouuly had 40-45mpg depending on the season. Ive had them for a week and it spring is here, so hopefully the mpg's will increase.
Montana
Old Mar 23, 2009 | 10:16 AM
livvie's Avatar
Montana
Did you go with OEM size tires? Also, do you have them inflated properly? Try going a few psi over recommended.
Old Mar 23, 2009 | 12:01 PM
montana41's Avatar
Hi Liv,
Yes, I kept the stock size 195-65-15 and stayed with the tire PSI the shop inflated to 30 PSI. I'll verify them after work.
Doesn't over inflating them whare faster? My originals wore fast, because i drive 65-75 on the HOV (another benefit of my 06 Hybrd) and even at those speeds I still averaged 40+ miles. I have a 57 mile daily compute just to work and back to home.
Old Mar 23, 2009 | 09:32 PM
gumby's Avatar
Energy Independence
Montana,
Inflating them within reason (certainly I'd go no higher than sidewall rated-max, usually 44 or 51 PSI) improves handling, traction, responsiveness, MPG, while it reduces tire temperatures (helping them last LONGER). The only thing NOT improved is the ride quality. The ride may be harsher and could introduce more rattles over time. I believe these two are the sole reasons that auto manufacturers "recommend" 26-32 PSI typically - for a cushier ride.
I go with about 35-36 PSI and have NO issues. I'm right at 50K miles. Many people go with higher PSI, and I may experiment more this summer.
About the MPG going down - this may just be because the tires are brand new. Once they wear in a little (maybe up to a few thousand miles), the MPGs should go up some. That's typical.
BTW, welcome to the forum. And I'm originally from Chesapeake!
Old Mar 24, 2009 | 04:52 PM
  #27
montana41's Avatar
Hi Steve,
Thanks for the info and encouraging reply. I'll experiment and bump my PSI little by little.
Not sure when the last ime you where in Chesapeake (city of draw bridges...lol). It has definately changed since moving here in 2000.
Montana
Old Mar 24, 2009 | 08:01 PM
  #28
gumby's Avatar
Energy Independence
Great Bridge, XMAS 2008. (Yes, I'm a Wildcat!)
But it had been many years before that visit.
Do get higher than the 26-32 PSI, at least. It's good for your tires, too.
Old Mar 26, 2009 | 06:47 AM
  #29
stevenvillatoro's Avatar
Arrow Re: What tires did your Honda Hybrid come with?
For multiple lengthy and well-researched general discussions on tire pressures, MPGs, and how PSI may affect other performance of your car or tires, go to Insight Central forums. Those hypermilers have studied the subject backwards and forwards. You will learn more than you ever wanted to know!
leepark
Dec 16, 2006 02:46 PM
lilbyrdie
Nov 8, 2006 05:41 PM
Tim K
Toyota Highlander Hybrid
Aug 22, 2006 07:25 AM
ElanC
Aug 6, 2006 07:27 AM
