Weird Friction Feel on 2006 HCH
Old May 18, 2006 | 11:21 AM
sri_gondi's Avatar
Default Weird Friction Feel on 2006 HCH
Hello HCH Drivers,
I noticed a Friction feel when I drove my 2006 HCH on a slow moving traffic at about 30-40MPH and occasional stopping this morning, I never drove my car this slow after I bought this one 2 months ago, I also noticed that I can see the Regenerative lights glowing but if the car goes beyond 35MPH then the Friction feel would vanish!!!! and the car would run smoothly. Did anyone notice this one? Is this something that I need to see my service centre for a check up? Or is this because the IMA is charging the batteries? Any input?
Old May 18, 2006 | 11:58 AM
riksmg1's Avatar
Default Re: Weird Friction Feel on 2006 HCH
hi
I would like to suggest next time when your coasting in that speed range put car in neutral and see if the dragging sensation goes away. If it does most likely your feeling the drag from the regeneration you should be seeing green bars. Ive found that for coasting you want to keep the gas pedal in a position where there are no green bars showing unless you know your going to have to stop. Also I found its easy to put the car in S instead of D. I have used the S when the engine has not warmed up completely and I have to stop. It will force it to go into regen.
Old May 18, 2006 | 02:48 PM
sri_gondi's Avatar
Thanks Rick ,I will try putting in neutral this evening and see how it behaves.Thanks for the suggestion.
hybrid-theory
15
Feb 9, 2015 09:33 AM
avp_warrior
May 2, 2012 01:05 PM
RezaR1@yahoo.com
Mar 5, 2008 09:30 PM
bigbearballs
Dec 13, 2005 06:40 AM
ericbecky
Mar 31, 2005 12:29 PM
