Upgrading 07 HCH Audio?
Old Oct 30, 2007 | 06:46 PM
iridium130m's Avatar
Default Re: Upgrading 07 HCH Audio?
Originally Posted by soldierbot
I used the stock placement for the tweeters on my front components. I have never had a system with the tweeters and mids such a distance apart but the sound quality and staging is very nice.
How did the replacements fit? Were you able to keep the grill and such?
Did you reuse the exisiting wire or replace?
Thx!
Old Oct 30, 2007 | 08:57 PM
soldierbot's Avatar
Thx!
I ran new speaker wire but you could use the stock wire if you chose that option. Yes, the tweeters fit in the original location fine with the grill back in place. The look is completely stock.
Old Nov 2, 2007 | 08:53 PM
zo6 2 hch's Avatar
Originally Posted by arbittan
Have you tried the Honda OEM Bass Kit? It is about 300.00 and replaces your two back speaker with a amped 8" x 2 woofer system.
I have been toying with the idea of getting it. I have not heard of anyone having it installed.
Your resale value should not go down if you install a third party audio system. You can chalk it up as a premium audio system in KBB.com.
If you are looking to totally upgrade, think about a total Alpine solution (since Honda uses Alpine already). You can then have BT handsfree in the car and iPod integration!!
Ummm, yeah so how do we install the OEM bass kit considering we cant put down our back seat? http://www.hondapartsdeals.com/honda...ker_System.pdf
Old Nov 3, 2007 | 05:26 PM
arbittan's Avatar
Actually, the Genuine Honda OEM instructions do not state you need to lower your rear seats.
http://www.hondaautomotiveparts.com/...f/AII33518.pdf
All of the installation work is done in the truck location. You will need to remove the rear speaker grills in one step to install the speakers, they install top down instead of bottom up.
The method Honda is using to get bass into the car is good, but I don't know what type of bass comes out of those speakers. I like to listen to classical music every now and then and I would like to really hear the lows replicated. Especially if the piece performed is pianissmo and fortissimo (very quiet and very loud) or a mixture.
When I mean method, I mean not having to run a thick amp cable from the battery to the trunk. I really don't want to cut into my wiring/splice.
Old Nov 4, 2007 | 06:30 PM
zo6 2 hch's Avatar
Im curious as to the quality of the bass as well, the kit replaces the existing speakers with 2 8" speakers correct? That might sound pretty good, I wonder how many watts the amplifier delivers to them. Does anyone have this kit that can attest to the bass quality?
Old Nov 6, 2007 | 11:02 AM
arbittan's Avatar
I called Honda parts today to order the Bass Kit. My cost is a lot cheap than the retail parts cost. I will find out how well they sound once they are recieve them and I install it.
Old Nov 6, 2007 | 11:40 AM
  #27
arbittan's Avatar
Also, has anyone tried this http://www.hondaautomotiveparts.com/..._Subwoofer.jpg
It is made for the CR-V but might work with the Civic since it is the same Radio.
Old Nov 7, 2007 | 08:16 AM
  #28
arbittan's Avatar
Okay, I ordered the BASS Kit. I should get it by the weekend for installation.
My cost is little over $120.00
Old Nov 9, 2007 | 12:24 PM
  #29
arbittan's Avatar
Anyone interested in the Bass Audio Kit for the Honda Civic to upgrade the sound, I will be posting my results to the installation and my assessment to the sound.
Old Nov 9, 2007 | 09:21 PM
  #30
giantquesadilla's Avatar
Arbittan:
What are you doing with the old rear speakers? I have a friend who may be interested in purchasing some for her Accord.
