Tour de Sol Monte Carlo results
Old May 16, 2005 | 06:12 AM
KLCarch's Avatar
hyperactive enthusiast
Default Re: Tour de Sol Monte Carlo results
Hey Jeff-
I'm in Rockland County- what route did you take?
I wanted to go to that pretty bad- but the kids had their big nys music solo festival so I had to do mom duty instead.
congrats on your great mileage- maybe next year I'll be there chasing you!
Kate
Old May 16, 2005 | 08:23 AM
n1ywb's Avatar
Eye am teh smartey
Originally Posted by KLCarch
Hey Jeff-
Kate
Basically, we started in Harriman, took 17 to 209 to 9W, hopped on 787 to get through albany, then 7 to 9 to saratoga.
Old May 16, 2005 | 02:00 PM
lars-ss's Avatar
Here is the most detailed account of the Tour I could find:
SYNOPSIS: Modified Honda Insight driven broke the 100-mile-per-gallon barrier over a 150-mile range in the National 2005 Tour de Sol.
Greenfield, MA - May 16, 2005 - A modified hybrid vehicle, a Honda Insight driven by Brian Hardegen of Pepperell, MA, has broken the 100-mile-per-gallon barrier over a 150-mile range in the National 2005 Tour de Sol held May 13-16 in Saratoga Springs and Albany, NY. A student team from West Philadelphia High School in Philadelphia, PA, has taken top honors with its purpose-built hybrid vehicle, which uses biodiesel instead of gasoline and produces 77% less climate-change emissions compared to a conventional gas car.
During the National 2005 Tour de Sol - the 17th annual sustainable-energy and transportation festival and competition -- over 60 hybrid, electric and biofueled vehicles from throughout the U.S. and Canada demonstrated that we have the technology today to power our transportation system with zero-oil consumption and zero climate-change emissions. Each vehicle showed new ways to reduce our dependence on foreign oil while reducing harmful pollutants.
The Full Story:
http://www.evworld.com/view.cfm?sect...ue&newsid=8474
Old May 16, 2005 | 04:11 PM
xcel's Avatar
Hi All:
___I am a bit sad as I sold the Little Beauty just before this all went down. I don’t know if Brian’s Insight hit the 107 mpg at 55 + mpg average but I am quite interested in the full results knowing the Insight with no mods other then high pressure in the tires will do > 105 in 75 + degree temps while traveling at ~ 50 mph. Depends on wind and traffic as well …
___Does anyone know if there was a non-hybrid, PZEV, SUV, or P/U truck class? I know where Hot_Georgia_2004, Lakedude, and myself will be when the next one rolls around? Maybe Ericbecky will let me borrow his Insight 5-speed for a weekend
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
Old May 16, 2005 | 05:11 PM
ericbecky's Avatar
Contributor ($)
xcel,
I'd be more than happy to loan my Insight for this event. In fact I was suprised that I didn't hear from you. This seemed like an event that would eb right up your alley. although some of the restrictions seemed a bit limiting. (For the "stock" category there were limitations on tire pressure, etc.)
Next year, the Insight drivers who have the MIMA (Manual Ingretated Motor Assist) will crush the competition.
Old May 16, 2005 | 07:57 PM
xcel's Avatar
Hi Eric:
___I have been asking similar questions over at Insight Central.
Mileage competition May 13-14 2005
___As for MIMA, I still have my doubts. The setup makes sense for more efficient cruise but hypermilers do not cruise. Look at the way Honda setup the AH’s ECO mode with Assist helping to maintain it instead of the loss of lean-burn w/ any assist as the Insight 5-speed’s do now. MIMA is mimicking the AH’s ECO mode w/ assist in some respects. The real item of note. Relying on the pack to maintain ECO mode in the AH is a lossy proposition vs. straight up “DWL w/out assist” while maintaining ECO mode as I saw in GreenAndBlue’s relatively brand new AH last month.
___In my view, pack use still involves a chemical (gasoline) to mechanical (ICE) to electric (alternator) to pack (chemical – battery) to propulsion (generator) conversion vs. a less lossy - chemical (gasoline) to mechanical (ICE) or “Driving w/ Load” (lean burn w/ no assist) while climbing. Until someone pushes an Insight’s lmpg into 90 + over maybe a minimum of five to ten thousand miles with the MIMA setup, I still see the conversion as a lossy overall solution vs. the non-assist climb w/ Lean-Burn or straight up DWL lean burn method myself. Pack use helping to maintain lean-burn is a great help to those without care to maximizing ones FE but driving with a maximum of lean burn and little to no battery charging is still the most FE way to drive an Insight in my book.
___I am sure you saw the 118 mpg gauge cluster shot as well but was that from a cold dead stop or was it an FCD reset while traveling down the road at 50 mph and then coming to a stop after 15 miles? There is a huge difference between starting from a cold dead stop and running up to 117 mpg over how ever many miles vs. running at 120 mpg and resetting the FCD for just 15 miles. I just haven’t heard which was used in the pic yet?
___That 55 mph // 100 mpg // < 45 #’s in the RE92’s is one that would be the tough one to overcome. I know of a way to meet the target with relatively flat terrain (~ ½ of Ohio) but I am not so sure there is a way to hit it with any kind of large elevation changes as is the case with some areas of N.Y. I didn’t just experiment with high FE Mountain climbing on my way out East last month as you can well imagine
___Good Luck
___Wayne R. Gerdes
Old May 16, 2005 | 09:36 PM
ericbecky's Avatar
Contributor ($)
My thought was that since you have true 90+ mpg hypermiling skills you might have a better shot at using the MIMA to meet the 500 mile/100+ mpg challenge. I figure adding something like a square moving van ahead of you to create draft would help the mpg even more.
I haven't heard which was used either. I mean I can set up a 100+ mpg shot like that by resetting just before one of my long hills and driving easy terrrain with no stops for a while.
RichC
May 19, 2005 07:38 PM
lars-ss
Honda Insight
May 16, 2005 10:13 AM
KLCarch
Events & Gatherings
Apr 15, 2005 05:05 AM
eklisiewicz
Events & Gatherings
Apr 6, 2005 08:56 AM
