Top 5 Tips for Maximum MPG
Old May 11, 2006 | 07:29 AM
JJanney's Avatar
Default Re: Top 5 Tips for Maximum MPG
Originally Posted by kenny
Top One:
Drive as if your brakes have failed.
This is quite possibly one of the easiest and best tips floating around. Not only can you keep the State of Charge of the battery higher by using the Regenerative Braking to slow you down a good bit, but your mileage will increase also.
Old May 11, 2006 | 10:37 AM
JCarter's Avatar
I find that temperature has more effect than anything I do. Since Spring arrived my mileage has gone from low 40mpg to mid 50mpg.
However I find the car does best when:
I keep in the right lane and go fairly slowly (not to be dangerous or discourteous).
Use CC as much as practical... except where steep hills are involved.
Try to anticipate and minimize use of brakes.
Drive with the load in hilly situations.
Old May 11, 2006 | 12:22 PM
mmrmnhrm's Avatar
Wo ai Zheng!
Originally Posted by lakedude
You can draft or surf but I think those are dangerous.
I'd never heard of surfing until reading that article, but if you're doing it on the left side, I don't think it's really all that bad. The truck driver can see you clearly there, and I can't remember the last time I saw a truck change lanes without using their turn signals (letting you scoot ahead as soon as you see them blinking... you *are* using your mirrors, right?). Drafting I don't do simply because I hate being that close to something throwing up paint-chipping rocks, though I do tend to follow trucks somewhat closely in the fall when the deer are rutting. I'm far more confident in their ability to just plow through them than in my ability to stop.
Old May 11, 2006 | 07:38 PM
westweb's Avatar
Hyper Hybrid Dude
#1 Don't let your spouse drive your car!
#2 Patience. Helps to leave a little early. Enjoy the drive at 55!
#3 Prepare. At least one mile in advance.
#4 Observation. Of your surroundings, so to reduce quick braking/acceleration.
#5 No AC. CAN'T DO THIS ONE MYSELF...TO HOT!!!
Old May 12, 2006 | 11:29 AM
moosh's Avatar
Owner
Default 4 Points
I'm on my 5th tank and these 4 points stand out as "Lessons Learned"
1. Tire Pressure - Should be what is recommended. Do not go to the cold max. I did, and a tire sprung a leak. My best MPG trips have been on recommended PSI.
2. Route Selection - Find one where there's little traffic and few stops. A 2 lane road is ideal because cars behind you will either turn off or pass.
3. Expressway Driving - Where there's a 70 MPH Speed Limit, set the cruise control to 61 or 62 MPH. Wind resistance doubles from 55 to 70 MPH. However, driving 55 MPH in a 70 is taking it too far.
4. Acceleration - Get to ideal speed and slowly let off the accelerator until the IMPG gauge is around 75 MPG. This provides better results than trying to maximize the amount of time at 100+ MPG and saves the IMA for stops, let momentum be your friend. BTW, Auto Stop won't kick in at 4 bars or less.
Old May 12, 2006 | 10:26 PM
lakedude's Avatar
This is probably number one if you are in a relationship. Typically one member of a couple cares waaaaaay more about mileage than the other.
Old May 13, 2006 | 12:58 AM
Hot_Georgia_2004's Avatar
Lots of great top 5 tips here.
The more you apply them proportionately you'll see results.
Take it to the extreme and see extreme results.
Don't think one can master it in an afternoon drive: it's a skill to be learned.
This paticular skill can save you 10's of thousands of dollars in fuel costs in your lifetime.
Old May 13, 2006 | 02:01 AM
Double-Trinity's Avatar
I believe wind resistance would be a bit less than that, or about 1.6 times (assuming resistance proportoinal to the square) 55 -> 78mph would be double.
Anyway, here are my top five tips to save fuel without reducing overall average speed, most of them have to do with city driving (whcih I actually don't do very often, my MPG would probably be better if I did more of it):
1) Set tire pressure to the highest level you're comfortable with (as far as ride/noise level), not exceeding max cold sidewall.
Not only does this reduce rolling resistance noticably (I actually coast faster down known stretches of hills at 44psi as opposed to 30), it improves handling and hydroplaning performance as well. Drawbacks are a bumpier and noisier ride.
2) Pay attention to traffic light timing, coast from as far back as possible if you suspect the light will be red when you arrive.
This one is quite broad for a single point, and probably takes the most practice of anything, though it can be huge for city driving efficiency. The key though in the city is to coast to lights if you suspect they will be red by the time you get there. This will use no extra fuel, save your brakes, and take no extra time as you'd need to stop anyway.
3) If a ine of backed-up cars is formed, approach it at just the right speed so that you reach it just as it disperses
This is applicable both in city traffic, such as a backed up line of cars at a signal that has just turned green, or in highway traffic congestion conditoins. It also has the benefit of improving the fuel efficiency of drivers following behind you in a sort of chain reaction, multiplying the environmental benefit of using less fuel, all without decreasing average driving speed.
Another more "advanced" application of this has to do with approaching red lights, and guessing when they will turn green. This can be done by analzying the cross-traffic on the intersecting road -- if lots of cars are moving through, it will probably stay red a while, so you're best off getting in as much regenerative braking as possible. If they are beginning to stop, and there are no cars in line to turn left, the signal should turn green soon, in which case coasting is a better option, so you'll already be moving when the signal turns green.
4) Balance air conditioning load
When air conditioning use is necessary, run it at a high temperature setting such as 82 degrees on flat stretches, run max AC on the coldest setting when going downhill, switch AC off when going uphill.
This basically balances out the load of the Air conditoiner. I personally wish Honda would have designed the "econ" mode to actually do this for me, rather than just be an on/off switch for auto-stop, but on long highway trips, it's not too much work to do this when coming to hills.
5) Drive with load over hills
This works both on highway and city rdiving as well, and is similar to the AC cylcing method, or more evently spreading out the work the engine has to do, so it can stay in an efficient powerband more of the time. This principle is acutally the basis of hybrid technolgy itself -- using the electric motor to add power rather than requiring the engine to run outside its efficient RPM range.
Finally, the reason I emphasize driving without reducing average speed is that I prefer to go with the ambient flow of traffic in order to reduce interactions such as lane changes, and speed changes. These are also all essentially "free" savings as there is no added time cost, simply a change in style.
cobalt293
Dec 15, 2007 10:48 AM
Jason
Hybrid & Related News
May 9, 2007 11:33 AM
pptudela
Mar 26, 2007 09:44 PM
SoopahMan
Sep 20, 2006 06:36 PM
