Splash guard
Old Mar 14, 2008 | 05:05 AM
cmk8895's Avatar
Default Re: Splash guard
There are 8-9 clips on the main guard under the engine (+2 bolts). There are another 6-8 on the secondary guard that goes under the driver's side to cover the brake lines.
That's a good idea to check online for the clips. I should have stated that I was in a hurry to get it fixed up after the guard ripped off, so I didn't shop around.
Also, I have not confirmed this, but the guy at Honda (which is also a Toyota dealer) said that he used to work at Advance Auto and they had those same clips for dirt cheap. Again, I have not confirmed this, but if there is an aftermarket clip that is the correct size it would be a heck of a lot cheaper.
Old Mar 14, 2008 | 09:56 AM
cbxtc6's Avatar
The Honda parts lady told me Autozone carries the same fasteners. Check it out, and let us know! It's GOT to be cheaper than the Honda dealer.
Old Mar 28, 2008 | 08:37 PM
bullet4's Avatar
the splash guard is also there to protect the oil filter from road debris.
the newer model hondas have an oil filter on the lower front of the motor instead of upper rear or passenger side.
as far as the clips we have a service news at honda that tells us to spray the clips with wd40 or triflow before removing in order to lube and get some debris out of them...seems to work the magic when removing those things
Old Mar 29, 2008 | 08:50 AM
caholla's Avatar
Hybrid Owner
I removed mine at 2900 miles to install the block heater and they were already a PITA to remove. I'll try WD40 next time, that's for sure!
Thanks!
Old Mar 29, 2008 | 10:04 AM
bullet4's Avatar
sure thing man im always happy to help where i can
mikieboyblue
Jan 19, 2008 07:34 PM
Soybean
Sep 2, 2007 09:49 PM
QuickSilver
Jun 15, 2007 01:08 PM
WRXSTi
Oct 5, 2006 05:39 PM
GaryW
May 31, 2006 04:12 PM
