Road Noise
Old Jul 23, 2005 | 07:45 PM
DTDRIVER's Avatar
Default Re: Road Noise
If you change to larger diameter rims, you them must have low profile tires put on if youplan to keep the same outside diameter which you should! This means less rubber on the sidewall heights. I doubt this will help anything but possibly the looks depending on what rim you get. If I were bothered than much, I would check on the quietness of another brand of the same size as on the current rim. Only problem, you got to buy 'em to try 'em!
Old Jul 23, 2005 | 10:06 PM
Tim's Avatar
Tim
Enchanter, Enthusiast
I'll definitely keep the same diameter - I'm sure the car and transmission are calibrated to a particular wheel diameter. Not going to mess with that. The 10 lb wheels were interesting - good looking too. However if the current ones are that much, there isn't much incentive.
Ian
Oct 16, 2006 05:55 PM
noflash
Sep 20, 2006 05:23 AM
Railroad
Jul 27, 2006 07:54 PM
robinb
Jun 26, 2006 01:35 PM
cburnap
Apr 29, 2006 11:44 PM
