Regenerative Breaking issues during warm up
Old Jan 5, 2006 | 06:10 PM
Irish1996's Avatar
Default Regenerative Breaking issues during warm up
I live in Toronto where it currently is around 0 degrees C (32 degress F). My '06 HCH, when not quite warmed up, will engage battery charging while breaking, but then quickly release the charging, which results in the car jumping forward and requiring extra pressure on the break. Are other HCH owners seeing this as well? I am only noticing it now, after 1800km.
Old Jan 5, 2006 | 06:21 PM
dkeane's Avatar
Default Re: Regenerative Breaking issues during warm up
I do not see this at all. Matter of fact, my regenerative braking does not occur until the car has actually warmed up a little. Not sure why this is though.
Iwould bring the car into the dealer, seems like it could be a safety issue
DKeane
Old Jan 5, 2006 | 06:59 PM
CGameProgrammer's Avatar
DKeane
Assist and regeneration do not engage until the battery has warmed up. This takes less time than warming up the engine and the battery takes a lot longer to cool off, so this isn't much of a problem.
Old Jan 5, 2006 | 08:35 PM
Irish1996's Avatar
It happens when there are about 4 bars on the temp gauge, but doesn't happen after the car is completely warmed up. Maybe there is a problem.
Old Jan 5, 2006 | 09:41 PM
nimbus2k's Avatar
Dual-Hybrid First Adopter
I don't notice it at all on the 03 HCH but the Accord does that "every time." It took a little getting used to that last-second "lunge" when autostop kicks in.
Old Jan 6, 2006 | 06:26 AM
Cold Canuck's Avatar
Notice a similar thing in Halifax as well. The car will "lurch" sometimes when the regen kicks out. This is after the car (battery) has warmed up to the point that the computer allows regen at all. On cold starts after an overnight period, the car will provide some assist, but no regen until the battery has warmed up. This is what I expected, based on comments here and in the manual. Drawing current from the battery (assist) will warm the battery up fairly quickly.
As expected, the car does not "auto stop" till the engine is warm. But sometimes on the first stop after it has warmed up enough to autostop, the engine will restart, if stop is long enough. I assume the heater has taken enough heat out of the cooling system, to drop the temp and cause the computer to restart the engine.
I do not find the "lurch" dangerous, after all my foot was on the brake, only a little disconcerting the first few times it happened.
Old Jan 17, 2006 | 07:15 PM
jsalva11's Avatar
I notice the same thing some times in the morning. Here in california, with temps in the morning from 40 to 50 right now (6AM). It is annoying and I think may be dangerous. Is not the lurch that happens when autostop engages while coming to a stop. It
begins breaking, then lurches like accelerating while you are actually breaking...
Also I think it takes a bit longer to warm up than the 03 I had before.
Juan S. Fernandez
06 HCHII 1100mi
Los Angeles, CA
Old Jan 17, 2006 | 09:20 PM
bluesesshomaru17's Avatar
sounds like a problem you should see a dealer about. If it wasn't a CVT, I would say it soulds like there is a load on the engine and the AT downshifted to a lower gear and would give the surge. Watch your RPMs the next time, see if there is any other subtle things going on, it will help you with the dealer and if being more descriptive might help someone help you on here.
I am having a weird surge on mine, but it is under a steady rate of pedal pressure and speed, and the mpg drop at the same time. I need to do some more driving to truly understand it since it is a rare occurance, at least we have warranties!!! Free parts and labor, I have an extended warranty that allots me a rental car as well. Good luck and I hope they car fix this problem fast and you stay safe until it is.
mj2000
Mar 30, 2010 04:56 AM
kirby
Nov 12, 2006 10:14 PM
cbmamherst
Aug 30, 2006 08:29 PM
vioarc
Jun 28, 2006 09:22 PM
Hovercar
Honda Insight
Jun 14, 2006 02:55 PM
