REGEN off when almost stopping
Old Mar 6, 2008 | 05:58 PM
2008 Honda CIvic Hybrid's Avatar
Default REGEN off when almost stopping
When this happens, braking power is reduced suddenly and one needs to step harder on the brake pedal. Is everyone experiencing this?
Old Mar 6, 2008 | 06:10 PM
msantos's Avatar
Eco Accelerometrist
Default Re: REGEN off when almost stopping
I wouldn't say I have to "step harder"...
... instead I would say that depending on the circumstances it takes a bit of modulating of the brake pedal pressure to make the transition a little smoother. With practice, not even the passengers will be able to notice the regen to hydraulic transition.
Cheers;
MSantos
Old Mar 6, 2008 | 10:14 PM
gumby's Avatar
Energy Independence
Yes, it's just the way it works. You'll get used to it, and before long it'll seem "normal". It IS something to be aware of, though.
Old Mar 7, 2008 | 06:36 AM
kristian's Avatar
Yeah, you will get used to it quickly. The only time I notice it (in other words: find it annoying) is on icy roads when I don't want to use my brakes. The car slows down well in "S" up until about 10mph and then I have no choice but to brake for the last few feet.
Old Mar 7, 2008 | 07:11 AM
giantquesadilla's Avatar
Yes you will definitely adjust to it and not even realize that it is happening. Just give it another month or so.
Old Mar 7, 2008 | 10:03 AM
raidfibre's Avatar
Yes, sometimes it's very dramatic. It's more noticeable if I'm tailing someone a little too closely. I consider it a reminder that I need to back off!
Martin
Old Mar 7, 2008 | 01:29 PM
noflash's Avatar
Ditto everyone.
Old Mar 15, 2008 | 03:57 PM
holicow's Avatar
I notice this more in the very early part of my drive. After everything has warmed up, it seems to nearly go away.
I must say that when the regen suddenly cuts off, you do have to watch it if you are not firmly on the brake pedal yet.
Old Mar 16, 2008 | 08:35 AM
Jess's Avatar
When I feel the Regen cut off, I immediately pump the brake to reactivate it.
EazyMack
Feb 7, 2010 10:00 PM
VampHuntD
Introductions
Sep 14, 2005 08:41 AM
zadscmc
Jun 14, 2005 07:22 PM
Sadie
May 4, 2005 03:17 PM
SCHybrid
Apr 23, 2005 02:43 PM
