post pic of Trans Drain Plug??
Old 03-10-2008, 07:38 PM
HALOINSTR's Avatar
Default post pic of Trans Drain Plug??
Did a search but couldn't find any pics... Can someone please post up a picture of the location & the transmission drain plug for an 06 HCH? Please! I was going to change it but didn't want to pull the wrong one. Thanks!
Joe
Old 03-11-2008, 08:33 PM
giantquesadilla's Avatar
Default Re: post pic of Trans Drain Plug??
Here is an illustration of where it is located. I hope this is what you needed.
Old 03-12-2008, 12:15 PM
The Great Gazoo's Avatar
Great illustration, How many quarts of CVT fluid are needed for this simple oil change
Old 03-12-2008, 04:34 PM
HALOINSTR's Avatar
Thats GREAT! Thanks for the picture, I'm going to run out and try it.
Old 03-12-2008, 06:49 PM
HALOINSTR's Avatar
Mine took 3.5qts
40K and it didn't look bad at all!
Old 03-12-2008, 07:21 PM
No problem.
Did you just change it, or did you do the 3X flush? There has been a lot of debate on this website on which way to do it.
Old 03-12-2008, 10:36 PM
HALOINSTR's Avatar
Originally Posted by giantquesadilla
No problem.
Well when I pulled the plug, I noticed the fluid barely had a tint to it. so when it was done I just poured half a qt down & let it drain out, when that was gone, the remaining fluid that was dripping out was clean. So I didn't do the 3X...just pluged it back up and filled! Took alot less time & effort than I anticipated. Although I didn't pull the fill plug. I just went thru the dip stick.
Old 03-13-2008, 05:59 AM
3.5 Qts. Thanks Haloinstr
Old 03-13-2008, 09:43 PM
HALOINSTR's Avatar
No prob, good luck!
kalamazoo
01-22-2010 04:53 PM
MichelleVueHybrid2009
Saturn Vue Green Line
11-08-2009 05:10 PM
HiCap
08-26-2008 10:05 AM
Sphinx88
07-17-2008 01:51 PM
phendyr
04-15-2008 08:46 AM
